Anybody else notice the slight "Click" when starting off either in forward or reverse?
TheJackel2013
2021 F150 Lariat
Mine clicks too. Very faint and can only hear with windows down. But it’s there. I feel no mechanical vibration or shudder. Just the audible click.
jrdelong1043
Joe
Summer22!
2021 Mustang Mach-E premium, Lightning Lariat
Arborist
I hear a click when I take off with the windows down. Very faint but it’s there. When I almost stop I can here it as well. One pedal drive. Sounds like okay in the axle, maybe it’s normal. Heard it since day 1. Almost 5k miles. My Mustang Mache is silent. Maybe it’s normal. More of a axle click it sounds like.
Mike G
Mike G
N. AL, USA
Exactly what I'm hearing. And as you say, you don't have to completely stop for it to click again. Like half-shaft play or if there is a torque link on the motor that's flexing back and forth when you accel/decel.
Gimme_my_MME
Can someone get a recording of it?
jrdelong1043
Joe
Summer22!
Arborist
Yes, maybe it’s normal. I had my axles replaced in my Mache, I argued that it was the axles and ford said, we think it’s the motor. Replaced the motor, and noise still there. A clunk when I turned a hard left or right at 5-10 mph. It was the axles. Hopefully it’s normal, or maybe the lightning has faulty axles as well. It doesn’t sound bad, but most definitely a solid click noise.
TheJackel2013
2021 F150 Lariat
An update on my clicking noise. I took it to the dealer.
Can only hear with the windows down. It’s from the rear of the truck. To me it sounded like loose axle nuts on a CV. Techs at the dealership thought so too. They tightened everything down at the axles and brakes and the noise is still there.
Techs are stumped and will be following up with Ford corporate engineers.
Mike G
Mike G
N. AL, USA
Excerpt from a longer version taken with the GoPro clamped to the trailer receiver:
AT193
Aaron
New Jersey
2022 F-150 Lightning - Lariat SR - Antimatter Blue
I've also had the clicks happening to mine when I take off and almost come to a stop. I feel like it's not a mechanical/electronic cause because it's not really exact or perfectly repeatable. Sometime it's quieter, and often the clicks are not lined up on driver side and passenger side. I keep thinking it's some kind of metal tags hanging on something down there and sliding around. Or maybe there's an abacus under there that they mounted to help the GOM do it's thing 😂
Mike G
Mike G
N. AL, USA
I would take spare tire off and look around.
I might take it off and do another video to see if there's any movement that correlates with the clicking. It's gotten so that half the time I don't notice it anymore, it's always there when even slightly accelerating or decelerating. I don't have the radio on cause I like it quiet, so the noise is pretty easy to hear.
I did videos of the left and right front as well, but it's not clear where the noise is coming from really.
Mike G
Mike G
N. AL, USA
Yesterday, the 31st I was contacted by the Ford media rep and provided my details. Today my dealership's service tech called me and I drove down to talk with him about the issue.
At his suggestion we grabbed the keys to the dealer's mannequin which is identical to my truck except for the addition of the Max Tow extra compressor, and I put it in 1 PD and we drove around the lot and on a side street, and their truck does the same thing. You don't have to be in 1 PD or use Auto-Hold to cause the noise to happen, it just makes it easier to demonstrate what's happening when accelerating and decelerating.
So not sure where this is going but the tech is hoping that Ford will be footing the bill for the labor on whatever diagnostic steps are next, or send the Dearborn "A" team, complete with lab coats and stethoscopes.... :cool:
DrZoidberg
SATX
Lightning Eternal Vestibule
Yup this is the noise mine makes. It also makes it going over bumps too without accelerating. It's almost liek a metal flex of the protective metal shield or something.
MapleMan650
Santa Cruz Mountains
'22 Ford Lightning Lariat ER, 2017 Ford Mustang GT
I.T.
Just checking in here, mine also makes the click/tick sound. Sounds like it’s coming from the front and rear.
