lmbrjak
Just got my window sticker. Blend date 11 Aug. can’t wait
Please share a snip of this section of your sticker if you want to remain discreet (not share a vin).
That way I can populated the Seq1, blend day Seq2 & Seq3 codes the max week volume on my tracker.
My stick as an example
The only risk I see is short term, someone else tries to bind Ford Pass to your VIN and the production worker, lot driver or transport worker clicks accept locking you out until you can take delivery, easy remedy then is to remove the authorization once you take delivery and setup your own access to the vehicle.What could happen if I put my VIN out there?" if you wish to keep your VIN private, that's ok
Sanitized my end of the table, BTW, are you now in the 8/8 build week? Last I had you in 8/15Well then I will keep mine private.
I will have to update you on all events to keep the tracker up to date.
What could happen if I put my VIN out there?[QUOTE=" if you wish to keep your VIN private, that's ok
No still 8/15 just checking on 8/8Sanitized my end of the table, BTW, are you now in the 8/8 build week? Last I had you in 8/15
