robertantal
robertantal
Robert
F-150 Lightning
engineer
was looking to do the Power Steps...is that hideous logo removable? Is it just a sticker or is it more "permanently" mounted?
It looks like it is just glued with adhesive tape.
MTBAZ
Dan
AZ
22 Lightning Lariat
rough country 2" lightning leveling kit
Did you install these at home or have a shop do it? Looks like an easy install, once you pull the Frunk tub the top of the struts are easy to access. Not sure if the strut drops enough without removing other connections to get the spacer on.
robertantal
robertantal
Robert
F-150 Lightning
engineer
Done at a local shop.
badger_7
Aurora, CO
2022 F-150 Lightning Lariat / 2021 Tesla Model Y
Network Engineer
They ate a lot of online wheel calculators if you search on google. If I remember right this one is https://www.tire-size-calculator.info/
Thanks. I found a few that I was using, but I like how that one has a few more bits of information vs the ones I checked out. I was looking at some new tires and just wanted to be sure to avoid the rub!
PungoteagueDave
Here are some photos of the AMP RESEARCH Running Boards PowerStep XL (AMP77152-01A) on the lightning. I recommend getting XL version so it will cover the ugly side wiew of the under carriage mounts and plastic battery side covers.
The problem with that is that the steps are then way too close to the ground when deployed, even with your raised truck. Put them on a stock Lightning and they nearly touch the ground. I put on the regular AMP boards, which are still pretty low, but have the dual motors, great solution without the bulky appearance that yours have. Also likely have a better effect on range.
robertantal
robertantal
Robert
F-150 Lightning
engineer
Here are some photos of the wheel poke.
Ford F-150 Lightning Stone Gray Lightning leveled on 20" Black Rhino wheels, blacked out LED light bar, cross bars, bike rack IMG_20230125_112553
Ford F-150 Lightning Stone Gray Lightning leveled on 20" Black Rhino wheels, blacked out LED light bar, cross bars, bike rack IMG_20230125_112734
