Just put these AUXITO led bulbs on my 21 f150 headlights and it took maybe 20 minutes to install low beam and high beam lights. I'd say that they're probably 20-25% brighter than stock but I'm not getting flashed as cars pass me because the focus is still pretty straight forward.
As @BennyTheBeaver notes - we are a friendly bunch, but you wanthttps://www.f150gen14.com/forum/. We don't replace our headlights, at least not yet.
ericpullen
Eric
Louisville, KY
A new tail light is a little over 1000.00 with tax. I have no Idea how much it cost to install. Was not back ordered, should be hear in a week.
Been there, done that. If you can find one on eBay and you didn't destroy the actual BIS module, you can quickly swap them for less money. I still have a spare BIS module, but they do require programming at the dealer to make use of a used one.
https://www.f150lightningforum.com/...is-sensor-to-new-tail-light.13461/post-288766
Blochead21
PA
Black 22 XLT 311pkg
I wonder what programming would actually be needed. Potentially just copy the values through Forscan into the new unit and it work?
asianman35
Baltimore
2023 Antimatter Blue Pro
I did the tailgate last week and the charge port doors today. They match the Lighting logo perfectly.
does that same etsy seller (motounway) sell the outlined charge port decals? I didnt see those and got the completely blue ones, I think id like the outlined ones better.
ddbrooke
Natrona Heights, PA
They do. You have to choose custom and say you want the outline blue version
BennyTheBeaver
I added 3D Matte Black tailgate letters the other day. Looks sharp on the Avalanche Gray (now I need a Black Ford Emblem).
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? 20230220_161153
Pod
2023 AMB Lightning XLT SR
do Those decals and the tailgate ones have dimension or are they flat? How hard is it to line them up correctly?
ddbrooke
Natrona Heights, PA
They are raised. Very easy to line up. I put them on without pressing at first so they could be repositioned if needed. Once they are lined up correctly I used a wallpaper seam roll to press them on.
