Calvin H-C
- First Name
- Calvin
- Dec 15, 2022
- Richmond Hill, Ontario, Canada
- Ford Focus Electric 2017, F150 Lightning Lariat
- Occupation
- Technical Trainer/Writer - Wayside Railway Signalling Maintenance
The door sticker (and FordPass) for my wife's '23 Lariat SR says 42 psi as well, and also has Generals for all-seasons. It was recommended by the shop that the same pressure be used on the Winters when they were purchased.I wonder whether the door sticker recommendations reflect the specific tires that the factory installed on your truck. My ‘22 Lariat ER door sticker says my Generals are supposed to be 42lbs, and I would normally use 42 lbs for any brand of tires I subsequently use when these need to be replaced.
Am I wrong?
My '17 FFE says 41, but the '13 ICE Focus we used to have was 36, so there seems to be some factor likely related to the heavier weight of the EV.
Some on here have mentioned inflating to closer to the tire manufacturer's maximum rating, and I'm not so sure that is the best advice. If the inflation is on the high side for the vehicle, the tread will wear more at its centre. Inflate under the optimal value for the vehicle and the tread will wear more at the edges.
How does one determine the optimal value if different tires are put on the vehicle? I suspect tire manufacturers have tables or a formula that can be used that takes into account the vehicle's weight.
