PJnc284
- Sep 30, 2024
- Garner, NC
- 2023 Ford F150 Lightning Lariat ER
Sounds like nothing to worry aboutI did shutdown multiple times, reset the test, and even unhooked the negative 12V terminal for a little while
SSM 51314 - DTC U3000:57 in APIM, TCU, GWM - Unable To Clear | MachEforum - Ford Mustang Mach-E News, Owners, Discussions, Community
If you are participating in Ford's Advanced Analytics (Tokens) program, it is normal to see U3000 codes in your APIM, TCU, and GWM modules that refuse to clear. This is expected since you are running a slightly different software build that enables the analytics functionality. Modules should not be reprogrammed or replaced due to this code alone.
