UncleTony
You will need to unplug the comma until you get the coupler then if you'd like to use your AC. If you're handy with a multi meter, i can get you a breakout board and tell you which pins to ohm out.I’m happy to test things out. My A/C stopped working yesterday WITHOUT power from the OBD port. I’m running it just of the USB cable and waiting for it to start up before driving.
A/C initially was working fine but yesterday morning was chilly so I manual turned off the “switch”. In the afternoon I went to use it as it had warmed up quite a bit but Now the “switch” illuminates but there is clearly no A/C.
