DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT
biers
Thomas
SW Washington
2022 Pro SR
Maybe I should be starting a new thread?
My truck installed BCM 24.5.1 four days ago (Your frunk now closes securely with the exterior button, even when your vehicle is locked...). I noticed this changed behavior probably about a year ago so I didn't think much of it when it installed.
However, I have now lost intelligent access functionality. Any one else see this? I'll need to find my cable and fire up the old for scan - after I brush back up on how to use it.
spdski
Miko
DFW
2023 Lightning XLT 311A
Same - and I don’t have access to my forscan computer or cable for at least another month or two since my stuff is in storage while moving back to WA. :-(
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Looks like this problem might eventually affect us all, so indeed let's start a new thread titled:
DIY: Installing Passive Entry To A Lightning - 2025 Firmware Fix
Whoever's is broken currently from the frunk update and can use FORScan to identify their current (the new broken) BCM firmware please start this thread and tag Jesse and I in the initial post.
And post this:
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT 1758315478257-
Likely all that needs to happen is that we need to get new BCM firmware files for an EG 312a and install them into our BCM. Should be that easy.
watts/up
23 Pro SR
Just following back up in case anybody similarly lost passive functionality after Ford has been screwing with WAL in EAP. Indeed the first few related registers in the BCM reverted to the 311A as-builts, had to go back in and modify them again. The affected blocks were:
726-18-01
726-24-01
726-27-01
726-28-01
The rest retained their values, but if you're already in there I'd go ahead and check them all.
@boggle can you confirm what update you’re referring to here? You mentioned EAP and WAL but was it the BCM 24.5.1 update?
boggle
CT
MY23 PRO
Seems to be related to 24.5.1 as I received that update on 5/8 and subsequently lost the proximity functionality and touch behavior of my handles. Those few EEPROM registers I noted have fixed it, no issues since.
watts/up
23 Pro SR
Thanks for the confirmation.
@ZSC100 I’m hoping that just FORScan changes are required to fix the issue.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Awesome, yea this is good news if just the config needs fixed.
I'd say still someone should create a new thread with the specifics and fix if they can it would greatly appreciated by many.
grantmethepower
Grant
LA, CA
2023 F-150 Lightning Pro
Hi all, I added the Passive Entry a while back and just this week it stopped working. I noticed a "Update Scheduled" notice but those have never caused any issue. Could that have messed it up?
I no longer have a windows computer and did not save any of my forescan stuff. It's been a while now so I sort of forgot the steps I did to make it work haha. I can go back through this thread of course but I'm wondering-is there an easy way to get this working again?
grantmethepower
Grant
LA, CA
I think I fixed it. It took a few days to remember how to do Forescan haha. But it looks like they just changed the first three entries. Changed them back and it is now working again
glicenji
Las Vegas, NV
Tesla 3
I can confirm that they messed the first 4 blocks in BCM. It took me 10 minutes yesterday to rewrite those values and everything is back to normal. These are the blocks:
726-18-01
726-24-01
726-27-01
726-28-01
MNG-HTOWN
Mohamed
Houston, TX
2023 F-150 Lightning XLT
Hey everyone, just tried to do the firmware update and it failed. Heart skipped a beat. Any help?
See picture.
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT imag
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Write a detailed email to: <[email protected]>
Include pictures,
Reload the files into the MFA dialog and screenshot that as well to show them what you are trying to do.
See picture.
