RedTib
Michael
2024 F-150 Lightning Lariat
Following because I also want to add to my Lariat, it's the only missing feature that would have pushed it over $80k.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I trust you got the $7500, that will make the $2500 to install ProPower very tolerable :)
123XYZ
SF Bay Area
2023 F-150 Lightning Pro
Awesome, let's pioneer this for so many. I wish I was closer I'd bring a case of beer over and we'd knock this out.
If you were within 1000 miles. I might happily drive to you to beg for some help.
123XYZ
SF Bay Area
What's the first step? Ordering parts or lifting the bed off and documenting what's already there?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I'd say the first step is to get yourself a PTS subscription, learn how to know I get the site and find part numbers and diagrams, and then score yourself a salvage module, I lost money is not an issue then go to your dealer and order the parts.
123XYZ
SF Bay Area
I'm a little confused. If I try to sign up for 12-month subscription to the Professional Technician System (PTS) for $399, the site tries to bundle in a one-year linense to the Ford Diagnostic & Repair System (FDRS) software for another $1500. Would I need both?
I have to say that I'm a lot more willing to spend somewhat more than $2000 on parts that will likely work and can almost certainly be resold if they don't work for me than I am to spend almost $2000 on licenses for software that I'm not sure I'll be able to use and know with certainty I won't be able to return or resell.
I've bought a questionably legal PDF copy of the manual for my truck, I'm happy to pay for a Forscan extended license and an OBD II adapter, and I don't mind buying new parts from the websites of the dealers that sell them well below MSRP. But, I'm not a professional technician and am not interested in paying $1900 for software intended for people who do this for a living to find out what exact parts I need to buy and get any procedures that are not included in the manual.
If it's just another $300 for software and it's something you're sure I can work with, I can do that, but I wasn't expecting to need much more than some advice on which parts are needed, the parts, the service manual, an OBD-II adapter, and Forscan software to change settings on the truck to make it know that it has a 7.2kW inverter in addition to the standard 2.4 kW inverter.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Sorry for the confusion, ALL of Fords offerings are confusing so don't feel bad. It took me a good while before I understood everything and how to navigate PTS and that I even needed PTS for what I needed.
You do not need FDRS.
You need PTS only:
go to : https://www.motorcraftservice.com/
Login with your Ford single-sign-on (for pass login)
Go to the top banner "Service Info" and you can select a 72hr subscription.
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM 1760571038507-w4
This service called PTS is really awesome. It's basically the same thing the service advisors and mechanics have at the dealers, in addition to FDRS (which is the OBD programming software). This system gives you cloud connectivity to your truck and shows all your service records as well as lets you look at the complete (legit/legal) manual, parts diagrams, troubleshooting guides, DTC maps, calibrations procedures, and I'm sure much more. There are a few slight differences in the dealer version in that you don't have to have permission to look at other people's VINs, but other than that it's the same. Once you buy it sometimes it takes 15min for it to become active and show up in "My Subscriptions".
I only buy it 72hrs at a time and you can save anything like wiring diagrams, hose diagrams, theory of operations, etc. if you just print to PDF. This is what I do. I have done this probably a dozen times over the past 3 years, and for each project I work on I just buy it and spend a few hours downloading everything I can possible think I'll need for a given project. It does help if you are ready to actively work on the project b/c there will be things you probably miss or need again that you for got to get or look at.
It's totally worth the $26 just to play around and get your feet wet. Let us know if you find a theory of operation for ProPower. It should list the CAN messages involved and give a very detailed description of the operation to help us understand what modules might need configured or updated.
Ford F-150 Lightning Installing Pro Power Onboard 9.6kW Inverter - OEM 1760571058916-v1
123XYZ
SF Bay Area
You need PTS only:
Cool. Thanks for the explanation. I'll buy a 72-hour license later today or tomorrow, poke around a bit over the weekend, and see what I can figure out. I'll plan to do it again when I have parts in hand because I know with certainty that I won't manage to print everything I need with all the cross-references.
If I had the VIN for a Lightning with the 9.6kW Pro Power On Board, would I be able to compare parts included on both trucks?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Yes, that's another reason it is awesome is you can look up diagrams for other VINs. The only part you can't do as a public owner is connect to other VINs via the cloud without the respective owners permission
mr2urbo004
CA
2023 Ford F150 Lightning Pro, Tow Tech,
Has anyone got this installed yet?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
mr2urbo004
CA
chriserx
Louisiana
$1500??? Is the orange color because it's doped with gold, wtf? I get that it's likely low O2 high strand count copper (correct me if I'm wrong here) HV rated, despite most cables I've seen being 600V anyway, that leaves the connectors, maybe $250 in wire, $1250 for connectors? Am I missing something?
Edit: I was seriously considering doing this until I saw this ridiculousness.
mr2urbo004
CA
Might be cheaper to sell the truck and get one with the 9.6kw pro power
