How does cabin heating work?
B177y
Olympic Peninsula, WA
Once you get into this cold of territory, you may want to use departure time. As mentioned above, you can do the math as to how much power you’re using to preheat. It really depends on the cost of your power to decide if it’s worth the comfort. I ran a bunch of tests on my 24 Flash last winter and it was anywhere from an extra .25 to $1 for me to preheat depending on outside air temp. I found I would recover most of this on the back end charge that evening though as I didn’t spend all the energy to heat on my trip. It was slightly more costly energy wise though, so pick your poison, comfort or quarters.
Departure times are a fun event with our trucks. The E Heat is really interesting in yours, I haven’t seen that and it makes sense they would incorporate that for the quick heating and just use the pump to maintain. About a half hour before my departure time on a cold morning it sounds like a small RC jet is spooling up for takeoff and I’ve been waiting for my neighbors to ask if everything is ok but haven’t heard anything yet…
Make use of your heated seats and steering wheel. For me, neither come off this time of year and I leave the truck on 72 Auto 3. One other thing that’s a PITA but may help you. If I ever feel a chill in the air and I don’t have a passenger (which means passenger heat is off), I will go into climate and flip on passenger heat. I think it’s the Dual button. This noticeably helps balance out the cabin. Just note this resets after you shut off unfortunately which is where the PITA comes in if you want to roll around like this.
Make sure the "driver focused" button is off on the climate screen. That keeps climate on for the entire cabin even through restart cycles.
rufustlong
Travis
WA
24 Flash
Nice tip, I will try that one.
Edit: Works great, thanks again!
HammoJ
2025 F-150 Lightning Flash
All this talk about being warm in the cabin and no mention of using the heated seats.
jwrezz
1996 Ford ExplorerXLT, 2006 Subaru OBS LLBean, 2024 Ford F150 Lightning Lariat
Teacher/Firefighter
It has been, a bit. I just used the cabin heat for the first time today (it was a brisk 28F when I left), but had been using only seat and steering heat until now!
Mcgyverrod
Rod
Santa Paula, CA
2023 F150 Lightning Lariat ER (Rec'd 7/13/23); 2026 Lexus NX PHEV
Retired x2
How do you know if you have a heat pump or not?
Ford used a conventional resistive heating system in the 2022-23 Lightnings. In 2024, they went to a heat pump. Additionally, I only use the heated seats and steering wheel but my temps rarely drop below 25 degrees in the mountains.
Magendi
Philly area
Lightning Lariat
I really, really wish someone would figure out how to disable driver-focused heat/AC in Forscan. It’s amazingly irritating.
B177y
Do you not have a button to turn off driver focused in your climate screen? I'm pretty sure it's stock, no ForScan needed.
Magendi
Philly area
Lightning Lariat
Yes, but every time I shut the car off it turns back on. I’d like it permanently disabled. I’m very willing to waste some power to make the cabin more comfortable especially when I have kids and/or dogs in the back.
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
Hmm... I am fairly certain my driver focused climate setting turns off automatically whenever it detects someone in any of the passenger seats.
F150guy
Garrett
2024 Lightning ER Lariat
Isn't Driver Focused saved with the memory seat? That way your profile/seat memory saves the setting. I know my Driver Focused setting is always off.
B177y
What year truck? (Hint: add the year to your profile).
My driver focused stays off even when it's only me. I turned that switch off a while ago and it hasn't turned itself back on since. The AC button on the other hand...
Magendi
Philly area
Lightning Lariat
Mine is a 2023 and I wish it was possible to get it to stay off. OTOH my AC stays on just fine. I really wish they could figure out software to match their hardware prowess.
NeighborGeek
Steve
2025 F150 Lightning Flash
I guess my truck Is special then because it makes no difference in sound on my truck, I don't hear anything with it on. If I had to compare to my other truck, it's dead silent.
It's loud when standing outside the truck, compared to what you could expect from an electric vehicle. When in the truck, it just blends in with the sound of the blower motor running.
RLXXI
3rd rock
Automotive Technician
When I figure out how to drive my truck from the outside I'll be sure to let others know. It's the old "If a tree falls in the forest and no one is around to hear it, does it make a noise" category.
Useless point simply to make a useless argument on the internet because someone is bored. WhoTF cares if it's louder if you can't hear it?
jwrezz
Teacher/Firefighter
Wow! You must be used to the cold. If I have my heated seats on the highest setting my entire back would be soaked, but my exposed front would be uncomfortably numb! I have been doing ok down to the 40s, but yesterday and today dipping into the low 30s and upper 20s has me using the cabin heat!
