Tow Mode vs Regular Mode Mileage
Fuego14
PB
Los Angeles
FIREFIGHTER
Hi,
I’m getting ready to tow my 16’ single axel camping trailer on a short 100 mile trip. It is very light and I can wheel it freely in my driveway by hand. It’s that light.
When I put the truck in tow mode it basically cuts my range in half. But, the trailer is so light, I have a hard time believing that it would have that much impact on my range.
Question: Can I just tow it in regular mode?
Will the range be significantly different?
Thank you.
Pat
Leave it in tow mode, also create a specific trailer profile, your truck will learn the actual energy needs for that particular trailer and should show more optimistic ranges in time.
niall
niall
lighten lairt
painter
You should set up a trailer and tow it and truck will adjust everything accordingly and will heat or cool the truck components .
It doesn’t matter about the weight it’s the height of the trailer at speeds will cause loss of range and it’s just under half on highways
Fuego14
Fuego14
PB
Los Angeles
FIREFIGHTER
Thank you - this is all great info - I will set up the profile for the trailer.
Pat
jdmackes
2023 F-150 Lightning Pro
I'd setup the trailer like everyone has said, but it seems to take a long time to adjust the values. I'd drive it around a bit and see what kind of miles/kw you're getting and go off of that. Whenever I hook up my travel trailer the truck still says I can only go 120 miles or so, but I get 1.7 miles per kw so I know it's really closer to 150-170.
Fuego14
Fuego14
PB
Los Angeles
FIREFIGHTER
Great, thank you.
Normal mode and watch your consumption trip for averaging.
Or tow/haul mode, probably won't make a difference, might even be worse efficiency.
Until you really understand the dynamics of your camper/trailer relative to your Lightning I encourage the appropriate drive mode.
Ford F-150 Lightning Tow Mode vs Regular Mode Mileage 1764676948969-8t
Hi,
Thank you.
Pat
axle..
To be clear, that is not your range, that is a prediction. When you setup the trailer, plug in, then ensure it sees the connected trailer (if not, select it in settings), it will start accumulating history for that trailer. As you drive, the range prediction will fluctuate as it adjusts.
By using the Trailer profile, all the poor efficiency you get by towing goes into that bucket. Then, when you aren't towing, the efficiency prediction ignores that history.
Tow/Haul is irrelevant as far as prediction.
When you unplug, make sure it goes back to No Trailer. Unplugging with the truck running may help. If it doesn't, select No Trailer, may have to do it more than once.
Also remember that the efficiency you get in winter is not the efficiency you will get in summer. And if it is windy, that will dramatically impact efficiency too.
Reactions: chl
Fuego14
Fuego14
PB
Los Angeles
FIREFIGHTER
axle..
Thank, great explanation. I’m learning a lot about my Lightning on this forum.
Fuego14
Fuego14
PB
Los Angeles
FIREFIGHTER
Thank you.
Fuego14
Fuego14
PB
Los Angeles
FIREFIGHTER
Thank you.
21st Century Truck
Martin
I've towed our teardrop camper all over the country, coast to coast+, with our Lightning.
BLUF: yes DO use the TOW mode. There are unseen software and vehicle sway & wheel force factors that are active in TOW which aren't active in NORMAL.
Weight of the towed trailer practically doesn't matter for the Lightning. Air resistance matters, a lot.
As a result of air resistance, speed while towing also matters, and the impact of speed on mileage changes logarithmically - the faster, the worse and above a certain speed the increase is geometric and not in a straight line. I found that below about 62 - 63 mph the towing range tax seems negligible. However, anything above 64 - 65 mph eats the remaining range. At a sustained 80 - 85 mph... forget it :shock:
Your profile doesn't give Your location... so if there are mountains (steep inclines) in Your camping trips, that also eats more range, when towing and overall, on any EV. However, this is a different loss than on a gasoline / diesel vehicle. On internal combustion vehicles, the elevation eats range available power, as altitude = less oxygen to burn, which means the fuel mixture gets richer with altitude. An EV doesn't burn anything so it doesn't care if You're driving at 14,000 feet... but an EV will absolutely feel the steepness of the incline while getting there. So the steepness of the mountain incline, added to the air resistance towing tax = significantly less range overall. Of course You'll get some back in descent, but not all of it.
Hope this is useful info for You.
Fuego14
Fuego14
PB
Los Angeles
FIREFIGHTER
Thank you for the great inof. I will also update my location. I live in Los Angeles and I'll be only beach camping at sea level no grades.
we've towed our 3,800lb single-axle typical camper for over 20,000 miles...
A) Tow Mode, per SE, does not determine your 'range'... it's simply a different REGEN level. You may also feel a slightly different amount of pressure on the GO PEDAL, but, again, that's simply a electronic/software difference... it matters not to range.
B) 'Range' is determined by all the typical factors, such as weight, terrain, temps, and SPEED. Towing doesn't change that, it simply adds another element to the equation - generally more about the AERO Dynamic effects from the front of the trailer/camper.
C) Your Drive Mode is your preference: it has nothing to do with 'towing', or not. As we have, you can also easily use NORMAL Mode, or SPORT Mode, just as well, if it fits your driving likes even better.
The LIGHTNING, or similar other EVs, doesn't use any 'suspension' differences, or 'transmission' differences, when towing: it doesn't change anything. It's all about your driving preferences.
If you choose to rely on the 'Range Indicator', you'll quickly learn that it is not a great indicator - it can't be: it doesn't know what the future holds, as to temps, speed, terrain, weight, aero, etc., it can only 'guess' by using past history of driving. It is generally never correct, and may even be TOO conservative, depending on your driving style.
If you don't use TOW MODE, it matters not, even though the truck is smart enough to know you have something attached to the hitch ball. Even if it doesn't, and your starting 'range' shows a more 'normal' number, it will quickly start to reconcile that as you drive. The internal calculations with the additional weight and aero will make the difference. You'll want to mostly make note of the mi/kWh indicator, which is your only REAL range indicator - keep your brain, or calculator, handy.
My PRO SR, with it's ~100kwh battery pack, makes for a much easier calculation than the other battery sizes...
