Jefro8
Jeff
CA
2022 Lightning
I was able to activate recently, hopefully someone who drives the vehicle accepts on the screen so I can track the truck. Lariat ER with bed liner. Also got an odd error notification in the app, not sure what it means yet. Ford Chat says truck is on Ramp 51, whatever that means… maybe it comes with some free space aliens.
Ford F-150 Lightning ✅ 8/15/22 Lightning Build Week Group 8D279664-B8D6-4C9F-AFAE-DF3BACE85F87
Ford F-150 Lightning ✅ 8/15/22 Lightning Build Week Group EF89AC9A-8D69-4399-BD9B-00202AF95A19
My 'Time in Status (Actual)' is at 13 days 22 hours. That coincides with when my window sticker became available on the 10th of August. Check your own to see if that is true for you as well. But it's still not clear what time span the 'Time in Status (estimated)' covers.
I'm already built, these values shift as you move stage to stage. the timer is accurately reporting elapsed timed since my dealer logged in my truck as received from the CONVOY transporter.
The problem is with the IN-Production stage not clocking correctly from invoice date on all builds, I have many samples and there are a few anomalies, APP/DEV needs to clean up that section of code.
I believe the ESTIMATED is an average/mean of all VIN's still in that stage, there are several long-timers still in each stage, skewing the composite
SteelTerp87
Chad
2017 F150 Lariat 2.7L (Platinum Lightning on Order
Self-Employed
Isn’t Ramp 51 the staging area for trucks awaiting shipment? If you have a spray in liner and this is the case then they have drastically improved that process. I hope that’s the case but who knows!
luebri
Neenah, WI
ScottyG
Scott
Ford Lightning XLT
I still have no window sticker, no modules, no status update on the tracker. No update or better info from Ford Canada or my dealer. When do I look in the mirror and tell myself my truck is not being built in this build week? :(
SteelTerp87
Chad
Self-Employed
What?!?! When did you find out you were in this week? Do you have a VIN? Have you tried
What?!?! Do you have a VIN? When did you find out you were in this weeks build?
ResidualJinx
Erik
Lincoln Navigator, F-150 Lightning, Mustang Mach-e
Long time listener, first time(ish) poster: Once mods/tag post and awaiting in spray-in liner stage, are we just in limbo till we get a built email or built status in the Order Tracking app?
SteelTerp87
Chad
Self-Employed
Basically. Ford told me delivery next week but with a liner I don’t buy it. Go on Ford Chat and see what they say
ResidualJinx
Erik
Their chat answer:
Based on what I can see, your vehicle is currently in production at the Electric Vehicle Center in Michigan. As of right now, the ETA is showing September 18th. Often times these dates get changed throughout the production and transit stages to reflect a more accurate estimate.
luebri
Neenah, WI
My chat answer just a minute or so ago: Your current order status is "In Production' and has been received at Ramp 51, Flat Rock, MI. At this time the order references an estimated delivery date between Sep-06-2022 - Sep-12-2022, which is only an estimate.
