1999-2021 Ford Truck SuperChips FlashCal Speedometer Calibrator & DTC Tool 1545
Stage3Motorsports
Arizona
2021 F150 STX CrewCab 4x4
Expanded coverage for the FlashCal Speedometer Calibrator & DTC Tool 1545
Some update information on the the FlashCal unit and plenty in stock for anyone interested.
Ford Flashcal #1545 for 2021 F-150 2.7L/3.5L/5.0L
Ford F-150 Lightning 1999-2021 Ford Truck SuperChips FlashCal Speedometer Calibrator & DTC Tool 1545 1642456467430
2021 F-150 2.7L/3.5L/5.0L is now added to Flashcal SKU 1545. The Flashcal is the easiest way to unlock numerous features not available on Ford’s new F-150 from the factory, and still offers the classic adjustments such as speedometer correction
Features and Options:
• Auto Start/Stop: Disables the Auto S/S and keeps it off every time you restart the vehicle after that, and can be re-enabled any time with the Flashcal.
• Enable fog light “Bambi Mode”: Simultaneous use of fog lights with high-beams.
• Honk Warning: Disables the 2-honk warning when driver exits a running vehicle with the key fob in-hand.
• Enable “Police Dark Car”: Turns off most cabin and exterior lights when the door is opened. This feature is often desired by hunters and campers.
• Daytime Running Lights: Enables or disables the daytime running lights, without having to navigate the Ford SYNC® menus.
• Auto Lights Display: Selects the duration of time the headlights stay illuminated after the driver exits, for 0, 5, 10, 20, 60, or 120 seconds.
• Auto Lock Disable/Enable: The F-150 will automatically lock its doors when the vehicle reaches about 15 mph. Flashpaq can turn this off so it will wait until manually triggered by the driver.
• Remote Unlock All Doors/Driver Door: Choose whether the first press of the unlock button on the key FOB unlocks all doors or driver only.
• Remote Start Duration: Adjusts vehicle running time after activation with optional durations of 0, 5, 10, and 15 mins.
• Axle Ratio: Calibrates vehicle speedometer for changes in axle ratios of 3.15, 3.31, 3.55, 3.73, 4.10, and 4.56.
• TPMS System Disable: TPMS can be turned off altogether for switching to aftermarket wheels without sensors. System can also be reenabled at any time with Flashcal.
• Independent TPMS threshold: With TPMS enabled, the front and rear axles can be set to different warning thresholds, from 1– 90 psi.
• Tire Size: The enter the measured height in inches, in a range of 28” – 40” for an accurate speedometer reading after changing to taller or shorter rubber, and the rest of the calculations are done for you.
IMPORTANT NOTES:
o Setting tire height below 29.25 or larger than 33.75” will trigger saved trouble code U0422, but had no ill effects on our test vehicles. If setting is restored to stock, or to a size between 29.5” and 33.75”, DTC will clear.​
o This release is for Ford Flashcal 1545 only. Flashcal 1545 does not contain tuning for increased engine power, only the options above.​
Stage3Motorsports
Stage3Motorsports
Arizona
How about the 22's?
It does come up on superchips website as 22 fitment so it should work, im going to see if I can get confirmation from them.
