Stage3Motorsports
Im sure these wont last long, and I know there are plenty of people waiting on Kings so I figured I would give the forum a heads up!
At the time of this post I have 2 sets physically in our possession and ready to ship, please contact me if you are interested to be sure we get your name on a set.
2015-2021 F150 4WD King OEM Performance Series 2.5 Adjustable Piggyback Rear Shocks (Pair) 25001-356A
Highlights:
King is one of the most famous names in off-road suspension and racing, so you know that you can trust their 2.5 Piggyback rear shocks for the 2015 to 2021 F150s to provide a huge improvement in performance over stock and allow you to take your aggressive off-road F150 build just about anywhere you need. These powerful shocks feature large shafts and pistons that are combined with a high-quality shock design and piggyback reservoirs to provide increased travel, improved rebound, better compression, and greatly reduced fade over your truck's factory rear shocks all while bolting right on in their place. On top of their excellent off-road performance, this pair of rear shocks is backed by King's legendary commitment to quality, and the shocks won't let you or your F150 down, no matter where you end up taking them. The piggyback reservoirs are even fitted with a King compression adjuster that allows you to tune your F150's ride and performance. High-Quality Shock Bodies with Anodized Aluminum Reservoirs
King combines larger shock bodies with a race-inspired internal design and then tops everything off with a piggyback reservoir so that you F150 gets a big bump in overall suspension performance. The rear shocks each feature 2.5" diameter shock bodies with large-diameter shafts and a heat-treated 6061-T6 aluminum shaft that helps maintain excellent ride quality while producing extra performance. The shocks are each made out of high-quality aluminum with an anodized finish and feature high-strength rod ends with spherical bearings that help minimize deflection. The reservoir of each shock is made from hard anodized 6063 aluminum alloy which greatly improves heat dissipation over internal reservoir shocks while resisting corrosion in practically any climate or application. The compression adjuster is located on the piggyback reservoirs and works by adjusting oil flow from the reservoir to the main shock body.
Returns: King does not accept returns on any of their parts, except in the case of manufacturing defects. Call Stage 3 directly at 623-257-0703 for more information.
Highlights:
- Huge improvement in performance and handling
- Can handle up to 2" of rear ride height over stock
- 2.5" diameter shock with piggyback reservoir
- Adjustable compression for tuning your ride
- High-quality parts and components
- Direct bolt-on replacements for stock
