2015-2022 F150 Magnaflow Street-Series Twin Side-Exit Cat-Back Exhaust Kit 19565
Stage3Motorsports
Arizona
2021 F150 STX CrewCab 4x4
Plenty of these in stock and ready to ship, for anyone interested shoot me a pm for forum pricing!
Ford F-150 Lightning 2015-2022 F150 Magnaflow Street-Series Twin Side-Exit Cat-Back Exhaust Kit 19565 1645132617720
Highlights:
  • Great sound with low drone
  • Features straight-through muffler and larger tubing
  • 409 stainless steel construction
  • Retains stock resonator for low drone
  • Twin Side-exit design with 4" diameter tips
  • Easy, drop-in installation
  • Backed by a limited lifetime warranty
  • Will not fit PowerBoost or Diesel models
Adds a Louder, More Noticeable Sound without a Bunch of Drone
One thing missing from pretty much all the 2015-2022 F150s from the factory is ant exhaust not at all. The good news is that the legends over at Magnaflow are here to help with with their awesome Street Series Twin-Exit Cat-Back for 2015-2022 F150s. The Street Series Twin-Exit Cat-Back kit from Magnaflow features an awesome twin side-exit configuration and a new muffler so that your F150 build gets a mean, deep rumble with completely changing up your F150's looks for a head-turning appearance. The Magnaflow Street Series Cat-Back Kit drops right into place of the factory cat-back system and features a quality construction that won't let you or your F150 down, regardless of application. Each Magnaflow Street-Series cat-back kit comes with all its necessary installation hardware and instructions. 409 Stainless Steel with 3" Tubing, Straight-Through Muffler, and 4" Tip
The Magnaflow Street Series Kit is made out of quality steel and is carefully designed for an excellent fit and sound on your 2015-2022 F150 build. The entire kit is made out of 409 stainless steel that's resistant to corrosion in most climates and applications. Each 2015-2022 F150 Magnaflow kit is built around a Magnaflow straight-through muffler that generates a louder and deeper exhaust note than stock. The kit installs on the end of your F150's stock resonator assembly, which makes for an easier install and helps keep your truck's drone down to a minimum. Each Street Series kit is made out of CNC mandrel-bent, 3" diameter tubing with a step-down connection at the resonator for a perfect fit. The kit is topped off with 4" diameter tips that exit behind the passenger's side rear tires for a great look. Magnaflow backs each kit with limited lifetime warranty and includes hardware and instructions.
Fitment: 2015-2022 F150
Will not fit PowerBoost or Diesel Models: this cat-back kit will not fit F150 3.5L PowerBoost Hybrids or F150 3.0L Powerstroke Diesel models.
Wheelbase fitment: since this cat-back system installs after the resonator, it will fit all F150 wheelbase options.
Graygoose2021
Central US!
2021 F150
Sales
the one I did, but had tips coated black. Excited to hear it on!
