Stage3Motorsports
The first of the RSI lineup for the 21 F150 has arrived, these are in stock and ready to ship!
2021-2022 F150 5.5ft Bed RSi EVOc Commercial SmartCap Bed Topper EC0306-WH
Highlights:
While even the most basic bed cap or bed topper is nice for bringing a lot of gear with you in a secure manner, most are made out fiberglass or composite that can't handle tough job-site applications. That's where RSi's EVOc Commercial SmartCap comes in. The RSi EVOc Commercial SmartCap for 2021-2022 F150s with 65.5ft beds is made entirely out of heavy-duty steel and features a modular design that allows you to add RSi accessories to customize the bed cap to fit whatever adventure you have in mind. Moreover, the RSi EVOc SmartCap feature's built-in T-slot rails on its top, which allows you to expand your F150's cargo-carrying capability even further or lets you haul large and bulky items on top of the SmartCap so that you don't have to leave your ladders, axes, or other large tools behind. Despite its heavy-duty design, the RSi EVOc Commercial SmartCap is extremely easy to install and uses a series of specially-designed clamps to hold the SmartCap firm to your F150's bed without the need for drilling, cutting, or any other permanent modifications. The SmartCap even comes with a built-in 3rd brake light that taps into your truck's stock wiring. Strong, Stainless Steel Construction with Large Windows and Built-In T-Slots
The EVOc Commercial SmartCap was built from the ground up to one of the toughest, most durable, and most capable bed caps on the market for the F150s. RSi manufactures the main body panels of the EVOc SmartCap out of stainless steel, which gives it much greater structural strength and durability than your typical fiberglass or composite bed caps or bed toppers while still being resistant to corrosion. Because of its steel construction, RSi was able to put 17% larger door and side openings than standard toppers, giving you easier and more effective access to all of your gear. The SmartCap comes standard with a Positive Pressure Air Vent that brings in fresh air into the cap which keeps dust out. The EVOc Commercial SmartCap also retains the factory third brake light for use as an interior cargo light so that you can find the stuff you're looking for after-dark. The built-in upper t-slot rails are capable of accepting t-slot legs from a variety of manufacturers, which allows you to build an entire t-slot based rack system on top of your SmartCap. The EVOc Commercial can support up to 330lbs of mobile weight and up to 770lbs of static weight, making it perfect for mounting heavy-duty hardware. Each SmartCap comes backed by a 3-year limited warranty.
Fitment: 2021-2022 F150 5.5ft bed.
For 5.5ft bed only: this version of the RSi EVOc Commercial SmartCap only fits 5.5ft beds. A version for 6.5ft beds is also available.
Highlights:
- Extremely strong bed cap designed for job-site use
- Stainless steel construction
- Modular design with built-in t-slot top rails
- Positive Pressure Ventilation to prevent dust ingress
- Easy, drop-in install with included clamps
- 17% larger doors and windows than standard caps
- Comes with third brake light and uses factory third brake light
- Backed by a 3-year limited warranty
