Stage3Motorsports
For anyone looking to a gooseneck hitch to their 21-22 F150 we have the B&W units in stock and ready to ship!
2021-2022 F150 B&W Complete Turnover Ball Hitch System GNRK1121
F150 B&W Turnover Ball Kit Features:
While the 2021-2022 F150s are more than capable of towing extremely large fifth wheels, trailers, and whatever else, but if you're towing at the bleeding edge of your F150's GCWR, then having a high-quality bed mounting solution is the safest way to go. The B&W Turnover Ball Hitch System for 2021-2022 F150s allows you to add a high-strength, heavy load-capable turnover ball hitch to your F150's bed with only a single cut into your F150's bed. The F150 B&W Turnover Ball Hitch includes a complete steel bracket system that bolts on to your F150's frame and comes topped off with a 2-5/16" ball that can either be used alone or in conjunction with any number of B&W's fifth-wheel hitches so that you and your F150 can easily and safely pull your trailer or fifth wheel of choice and bring all the gear and toys you need along with you on your next adventure out into the wilderness.
Heavy-Duty Steel Construction with High-Strength Hitch Ball and Minimal Levels of Cutting for Installation
The B&W F150 Turnover Ball Hitch features an incredibly strong construction and was carefully designed to minimize the amount of cutting and drilling you'll need to do on your truck. The bracket system is made entirely out of steel that bolts together with heavy-duty hardware and comes standard with frame-mount brackets that don't require any cutting or drilling for installation. The Turnover Ball Hit kit comes with a machined solid steel 2-5/16" ball that can handle loads of up to 30,000lbs, especially when paired with one of B&W's fifth wheel hitch systems. The kit comes with an extended handle that exits out the driver's side of your truck for releasing the ball, and utilizes a spring-loaded, 5/8" steel locking pin that holds the ball in place in nearly any application. The steel brackety all comes with a silver powder coat finish that keeps it protected from corrosion in nearly any climate. The F150 Turnover Ball System only requires a single 4" diameter hole cut in the bed for the ball itself, and the rest of the kit bolts on with included hardware. B&W even backs their hitch kit with a limited lifetime warranty.
Fitment: 2021-2022 F150
Will not fit Raptors: this hitch kit will not fit 2021-2022 Raptor models.
Requires cutting your truck's bed: this hitch system requires a 4" round hole cut in the bed for the ball. The rest of the kit features a bolt-on install.
https://www.stage3motorsports.com/a... 2021 F150 BW Turnover Ball Hitch Kit 00.webp
- Adds effective bed-mounted towing capability to your F150
- Complete Turnoverball mounting system
- Only requires a single 4" diameter cut
- All-steel bracketry with bolt-on install
- Features gray powder coat finish
- Backed by a limited lifetime warranty
