Stage3Motorsports
These new 2021 Specific F150 AirLift Kits are now available and in stock @ Stage 3
2021 F150 AirLift LoadLifter 5000 Ultimate Load Support Air Spring Kit 88355
AirLift LoadLifter 5000 Ultimate Features:
While the 2021 F150s may have some impressive tow ratings from the factory, but even at a fraction of your F150's total payload capacity, your truck's rear end can start to sag (especially if your 2021 F150 has a leveling kit), which can lead to handling and stability issues. To help level out your loaded ride and win back the stability you need to make it home safe, the grab the AirLift LoadLifter 5000 Ultimate Air Spring Kit for 2021 F150s. AirLift's 2021 F150 LoadLifter 5000 Ultimate Kit consists of a pair of inflatable air springs that bolt onto your 2021 F150 using high-quality, high-strength brackets and included hardware. When inflated, the two air springs support your F150's bed no matter what you're carrying or pulling behind you. The Air Springs themselves are rated for up to 5000lbs of load, which can support your F150's towing and payload capacities all the way up to its GVWR or GCWR. The Air Lift 5000 Ultimate Air Springs feature built-in jounce bumpers that allow you to run the air springs at 0psi. Each AirLift LoadLifter 5000 kit comes with all the hardware and components you need to get the system up and running on your very own 2021 F150 tow build. Pair of Durable Air Bellows with Strong, Steel Mounting Brackets and Hardware
The LoadLifter 5000 Kit comes with high-quality hardware that can handle practically any towing application you have in mind for your awesome tow-ready 2021 F150. The AirLift Kit is built around a set of air springs that are made out of a similar vulcanized rubber compound as tires and are resistant to moisture, oils, and the climate in general, allowing them to hold up to years of towing your gear and toys around. The springs are capable of handling 50psi to 100psi of pressure so that your truck can handle any load. Thanks to the internal jounce bumper, the air springs can handle being run at 0psi so that you don't need to keep constant pressure in your springs. The AirLift Air Springs attach to your truck using a set of thick, steel brackets with a black powder coat finish that blends in with the rest of F150's undercarriage while protecting against corrosion. The brackets install using included hardware with only minor trimming of your F150's rear brake line brackets and optional amount of drilling for mounting the air lines. Each kit comes with air lines with with PTC fittings that allow you to use them as standalone lines or in conjunction with an on-board air compressor. AirLift backs each their kit with a Limited Lifetime Warranty.
Fitment: 2021 F150 4WD & RWD
Will not increase GVWR or GCWR: this kit will not increase your F150's factory-rated payload, GVWR, or GCWR.
- Provides load support and stability
- Pair of air springs with brackets
- Can support up to 5000lbs of load
- Includes internal jounce for 0psi operation
- Comes with air lines and hardware
- Backed by a limited lifetime warranty
- Does not increase payload or GVWR
