2021 F150 Roush Performance Cat-Back Exhaust System 422266
Stage3Motorsports
Arizona
2021 F150 STX CrewCab 4x4
In stock with limited availability, shoot me a message for forum pricing and availability!
Frank
Ford F-150 Lightning 2021 F150 Roush Performance Cat-Back Exhaust System 422266 1636062155738
Ford F-150 Lightning 2021 F150 Roush Performance Cat-Back Exhaust System 422266 1636062171167
2021 F150 Roush Cat-Back Finish:
  • Adds a mean, head-turning exhaust note to your F150
  • Complete F150 cat-back system from Roush
  • Includes new tubing, muffler, and exhaust tips
  • 3" diameter, mandrel-bent exhaust tubing
  • Comes with high-flow Roush muffler
  • 304 stainless steel construction
  • Fits all wheelbase options
  • Backed by a limited lifetime warranty
  • Will not fit PowerStroke or PowerBoost
Provides a Louder, Deeper Exhaust Note in a High-Quality Cat-Back for your 2021 F150
There's nothing better than adding a more aggressive exhaust note to your 2021 F150 build, except when you can get a new note backed by the quality and fitment that you get from Roush Performance. The Roush Performance Cat-Back Exhaust Kit for 2021 F150 gives your truck a mean, instantly noticeable exhaust not in a cat-back system that both looks great and is made out of high-quality materials that won't let you down in nearly application or climate. Roush's F150 exhaust kit is a complete cat-back exhaust system that replaces your F150's exhaust components all the way from the mid-pipe on back to the the exhaust tips. The Roush cat-back features a twin-tip that exits in the stock location behind the passenger's side rear tire for a subtle change in looks. The Roush F150 cat-back kit drops right into place of the stock cat-back, though most wheelbase sizes will require some trimming for installation. 304 Stainless Steel F150 Exhaust System with 3" Diameter Tubing and High-Flow Muffler
Roush designs each of their cat-back exhaust kits for 2021 F150s for an excellent fit, with near-flawless quality, and with an exhaust note that is sure to turn some heads. Each kit is made out of 3" diameter tubing that's all precisely CNC mandrel bent to ensure smooth exhaust outflow while offering a perfect fit on your F150. The cat-back comes standard with a Roush high-flow muffler that generates a race-inspired exhaust note that's both louder and deeper than stock. The entire Roush exhaust system is made out of high-quality 304 stainless steel that's resistant to both corrosion and discoloration in nearly any climate or application. Both of the exhaust tips feature a rolled design and a polished finish with ROUSH lettering that gives your F150 a slick look. The Roush cat-back comes with all its necessary hangars and installation hardware, and Roush backs their kit with a limited lifetime warranty.
Fitment: 2021 F150
Will not PowerBoost or PowerStroke: this cat-back kit will not fit 2021 F150s with a 3.5L PowerBoost hybrid V6 or a 3.0L PowerStroke Diesel V6.
Wheelbase fitment: this cat-back comes with an inlet pipe that allows it to fit with all F150 wheelbase options, though trimming will be required on all wheelbase options shorter than 163".
