flypony53
- First Name
- Rodney
- Nov 2, 2022
- Houston, TX
- Ford F150 Lightning, Tesla Model Y, Tesla Model S
Ford changed the onboard charger for 2024 to 48A max for both Standard and Extended range. This shows up in the at home charging speeds. A shame really as you are trying to fill a battery that is almost 2x the size of the model Y at the same speed.agree but at least with my 24 platinum - the sports mode is almost smoother (definitely quicker off the line ) and should be the normal mode and the sports mode should be the normal mode if that makes sense…..at least compared to my 23 lariat.
the 24 platinum steering is stiffer as well in normal mode then my 23 lariat. I know this has been documented but since the 24’s charge at a slower rate then the 23’s - is that a software issue that can be OTA or is a physical reasoning to it ?
it’s a shame my 23 lariat gained about 35 miles per hour when charging at my 80 amp vs my 24 that barely gets to 20 . I knew that going in but didn’t think it would be that bad or noticeable.
If they can speed up charging at a super charger not sure why they can’t go back to normal charge rates then my 23.
EDIT to add link: https://www.ford.com/support/how-to...ightning-charging-frequently-asked-questions/
