Michael
BMW X5, BMW 528, Porsche 928
Sales Leader
Just had Toyo ATIII EVs (275/65r20) installed on my stock '23 Lighting Lariat (Max Tow). Replaced OE tires (275/60r20). The new sized tires fit without a lift or leveling kit. Pictures below...
Ford F-150 Lightning 34" tires on stock - THEY FIT IMG_6704
CaseyCo
Casey
Denver, CO
2023 Ford F-150 Lightning Lariat
Looks good! What kind of drop in efficiency have you seen so far?
LightningSauce
Michael
Sales Leader
Not sure yet...just had them installed today and drove ~8 miles home. :cool:
Nolander
Scott
2023 F-150 Lightning Lariat Extended
Following. Curious, how many miles did you get out of the Hancook’s?
NW Ontario Ford Lightning
Robert
NW Ontario Canada
2024 F-150 Lightning XLT
Contractor
Interested - hope you post the net results for everyone here.
I myself am interested in options for next winter, will run the factory set until next fall, then switch to a more suitable winter tire.
Henry Ford
They look great!
Any rubbing? How's noise compared to stock?
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
Still running factory Hankooks at 30K miles. Looking at replacement around next fall which will bring me around 45K. Id love to hear your thoughts and observations on these.
LightningSauce
Michael
Sales Leader
Additional notes/responses :
OE tire miles : ~15,000 miles; Tread was still great all around.​
Rubbing : none that I know of; plan to make a video of wheel range to ensure​
Efficiency : to be determined;​
Noise : did not notice anything outrageous and I drove home with the radio off.​
Pressure : 41 psi (new and old tires)​
Since I purchased the truck, i wanted to beef up the wheels...so I waited ~2 years to replace them. I work from home, so my annual miles are limited. As I drive more, I will update the thread with efficiency numbers.
roddiaz1
Rod
Pittsburgh
I got rid of my Hankooks at 36k because of uneven wear (caused by the front end).
jetfixr1
Manny
Atlanta
Do you know what was causing the uneven wear?
roddiaz1
Rod
Pittsburgh
I was unable to get to the bottom of it, but my guess it is camber/caster issue.
