GoodSam
p278 "Note: When you are following a vehicle and you switch on a turn signal lamp, adaptive cruise control may provide a small, temporary acceleration to help you pass."
Has anyone experienced this? Does this mean when you are following someone and indicate that you will be changing lanes with the turn signal, then immediately an acceleration is added, even before moving out of the lane? Seems weird.
I would think that this acceleration would occur only if you are going under your set speed, and you have moved out of the lane from behind someone so that there is more than your set adaptive gap availble.
