Ahem?!
PV2EV
That beats the ICE leftovers in the manual...
astricklin
99 Mercury mountaineer
So they'll still charge you $500 and do nothing.
And if you need brake pads on a lightning at 30k, you're definitely driving it wrong.
fafafoooey
Pat
Lightning
Maybe if you don’t use one pedal driving, you might need brake service.
Nope, even without 1 pedal the Lightning still uses blended braking, so it only uses that pads when you brake harder than it can regen.
fafafoooey
Pat
Lightning
Look at that, learn something new every day. So with non "one pedal drive", when you press the brake pedal, it will regen first, then apply brake pad when you need more umph?
Correct, no meaningful difference in efficiency whether you use 1 pedal or not. This is something that Ford does differently than Tesla.
Toby57
Randy
kansas
2018 F-150 XL 101A
Just too good. I wonder if there will be other dealers with something similar.
Somebody should send that to Ford EV.
p52Ranch
Bryan
OK
And here I thought I had leftover injector cleaner. I’ll get it out of the donation box for wayward ICE vehicles. It’ll be handy for my Lightning 30,000 mile service
Ford F-150 Lightning Ahem?! 26011473-A461-4407-B59C-87EB1B639C02
astricklin
Gotta make sure your electrons are clean
Robert
Hondo, Texas
F350 F250 F250 Taurus Cessna Super Air Natique
Retired Engineer & Product Developer
Watch your dash and even in normal and non - 1pd you should see regen in the left screen. Should open up a little with each brake application. Unless you really drop the hammer.
VTbuckeye
Joseph
Vermont
19 Bolt, 16 XC90T8, 22 XC40 P8 Recharge, 17 Tacoma
Maybe rust on rotors/calipers/slides due to infrequent use in the corrosive environment of the northeast in the winter?
