Anybody use WD-40 Electrical Contact Cleaner on the Charger or truck socket
Randy
24 Lightning, 20, Road Glide, 23 Kaw H2 SX SE, 24 Yamaha FX HO Waverunner, +
Ret. US Army Nuclear Artillery and Ret. P&G Mechanical Engineer
Anybody use WD-40 Electrical Contact Cleaner on the Charger or truck socket was wondering about paint etc.
K6CCC
Glendora, Calif.
I would not recommend it. WD-40 is not a contact cleaner.
Randys Lightning
Randy
Scorpio3d
SS/IBA car wash owner
I have used (CRC I think) electronics cleaner on mine it is quick drying, sounds like it is the same or similar, if if you just spray it on the contacts, then it should not get on the paint anyway because of the plastic around the plug. I could have gotten it on there, but I don’t recall and I don’t think it would be a huge issue if you did.
You are fixing a problem that doesn't exist. I don't know if it would cause additional problems but I do know that doing nothing won't cause additional problems and it's cheaper.
21st Century Truck
Martin
DeOxyIt is the way to go for any type of electric contact cleaning, tiny to (relatively) large.
Adventureboy
Ontario
Do not use any cleaner that leaves a protective residue behind (most do). The contacts must be clean with no residue to handle the current required for EVs.
Yellow Buddy
Mid-Atlantic
Smart Ass
https://www.crcindustries.com/qd-electronic-cleaner/
I haven’t sprayed these on my truck socket but I’ve used these on my trailers 30/50A plugs and trailer to truck contacts. I keep it in my truck and have sprayed L2 chargers that show signs of corrosion when I’m on the road both NACS and J17722 never used it on a CCS.
Adventureboy
Ontario
Adventureboy
Ontario
DeOxIT leaves a protective residue. This should not be used for high current contacts - especially DCFC. It works wonders on low-power electronic circuits and I use it for that.
Adventureboy
Ontario
WD40 Specialist Contact cleaner is not standard WD40 and is specially formulated as a contact cleaner. I have not used it for this purpose but it states that it leaves no residue, which should be ok for cleaning the port and gun contacts.
Definitely do not use standard WD40 for this, as it leaves a light oil residue.
