My Speed sign recognition not available
prvpilot1
James
Mankato Mn
2022 Ford Lightning Platinum
Today, anytime I would engage the cruise, I would get the message "Intelligent Cruise Control Speed Sign Recognition not available"
Ford F-150 Lightning My Speed sign recognition not available tempImageRPoJ4E
Crilly
Dale
Hartford wi
2 Mache GTpe
For sum reason, (new download) you have to have the map pulled up on the screen for it to work. Not the little screen.
prvpilot1
James
Mankato Mn
boy that will be irritating. I leave mine on my radio page
prvpilot1
James
Mankato Mn
On the drive home it works again!?!?
MickeyAO
Mickey
San Antonio Tx
Might be a camera and angle of the sun problem.
AZT9
Peoria, AZ
Mine did that once in the year I’ve had the truck. It was random, at night and self corrected. ??‍♂
IanHancock
Ian
F150 Lightning XLT 2022
Mine has been doing this regularly maybe since April. It was definitely a day after a software update. My dealer is talking with ford tech support but they have no clue. Has anyone had this issue solved? There are times when it works just fine others when it just will not work even after multiple starts.
Crilly
Dale
Hartford wi
2 Mache GTpe
Mine started doing it also after an up date. My fix is to but screen into navigation mode. It then takes a couple of minutes to load the map. Then it works fine.
Mike G
N. AL, USA
This sort of thing happens after updates. Normally clears after a keycycle.
IanHancock
Ian
Unfortunately it has been happening since April so key cycle did not fix. At least I have the info to beat up ford.
data003
Maine
2022 F-150 Lightning Lariat ER (Totaled), 2025 F-150 Lightning Flash ER
Try holding volume down and seek right buttons down together until Sync restarts.
