Camping road trip in Lariat
MattVT
Matt
Vermont
2025 F-150 Lightning Lariat
This past weekend we took our brand new Lightning Lariat on its inaugural road trip - a weekend tent camping on Deer Isle, Maine. All in, between the drive there and back and a few short drives around the islands, it was just short of 800 miles (the truck had less than that on the odometer when we set out).
We charged to 100% and then relied on public chargers after that, using the trip as a bit of a learning opportunity to try out different charges. We stopped more than we had to, taking the opportunity to get more familiar with DC fast charging - and stretch our legs on the long drive! On the way there we stopped at 3 different Tesla Superchargers, plugged in at a ChargePoint at a grocery store, and finally a local solar company offering 100kW charging for a final charge before heading onto the island.
We struggled at the first Tesla Supercharger, a v3, since we couldn't get the cable to reach while parked in forwards - spanning two spots. Fortunately it was early and there was only one other car charging, so we parked sideways to charge. On the way home we also stopped at a v3 charger and this time were able to get close enough to just make the cable reach - we learned not to straddle the line but to park completely in the space to the right, and pull all the way forward (we had to pick a spot without a bollard between the chargers) as far as we could.
The Tesla v4 Superchargers were much easier to use with the longer charging cables. We did have an issue with one charger where it lost connection a few times and we had to unplug / replug it in to restart the charging. I'm guessing it was just a faulty charger rather than anything we did wrong. The v4 Superchargers with the MagicDock worked great, although functionally no different from the Ford NACS adapter that came with the truck.
On the way there we noticed on the campground website that they had an EV charger on-site - something we hadn't seen earlier or were relying on. We called ahead to our friends who were already there to find out more. They spoke with the owner who said the charger was not yet installed, but we could use the 20A power at our site if we wanted to.
We arrived at the campground at 5:30pm at ~65% charge, confident that would be plenty for a few days of local trips, regardless of on-site charging. The combination of frunk, cab and truck bed made packing our tent, chairs, cooler and camping gear really easy. We set up and plugged the truck in to charge.
The next morning we awoke to find we, and several other sites around us, had no power. The FordPass app showed we had lost power just before midnight. Our friends have a young baby so we swapped our truck with theirs so we could plug their RV in and power it off the truck bed connection and get them back up and running. Off-grid camping was absolutely one of our use cases for buying this truck and getting the ProPower package, so it was great to see this worked exactly as planned - including with the adapter we had bought prior to the trip.
A few hours later the owner arrived to fix the issue. Turns out that a breaker had tripped - likely because it was the first cool night in a while and with several last minute bookings, all the sites were full. Several of the yurt-like structures had electric heaters, plus a couple of RVs and us, and the 30A shared between those sites wasn't enough. So yes, I guess we were (at least partially) to blame for the outage - oops! I told the owner that we didn't need to plug in if it was a problem, but he was insistent that he would find a way - eventually getting us plugged in with a heavy duty extension cord to the site next to ours which was on a different breaker.
Overall on the trip we consistently averaged ~2.4mi/kWh (~26kWh/100km) which I was pretty happy with - I just stuck to the speed limits and we took our time. Most of the DC fast charging cost around $0.40/kWh including the Tesla membership which our math showed us would quickly pay for itself. The truck is a stock 2025 Lightning Lariat with the factory-installed All Terrain tires inflated to 42psi (a little above the 36psi recommended), and a Bakflip tonneau cover that I installed. There were two of us in the truck plus I'd guess ~300lbs of cargo.
While we're no strangers to long road trips and camping, this being our first such trip in the truck gave us a little anxiety, but we needn't have feared - everything worked incredibly smoothly. Coming from my previous 2016 F-150 Platinum 3.5L EcoBoost, this truck was even more comfortable and easier to drive - BlueCruise handling miles of interstate with minimal user intervention required. Being able to power a cooler in the truck both while driving and while parked was awesome - we picked up fresh lobster and oysters from the harbor and yet could still go for a hike on our way home knowing things would stay cold.
All in, we came away from this trip even happier with our choice of truck. We had debated an ICE F-150, a Ranger, and various other vehicles before eventually landing on this one when we bought it a month ago, and for this trip, the Lightning was pretty much the perfect choice.
Did you lower your power draw to 16amps on the 20amp circuit?
MattVT
Matt
Vermont
I was using the mobile charger with the 15A plug and the truck reported it was pulling 12A.
Our site had a sub-panel with 3x 20A breakers, each one connected to a duplex receptacle, and the mobile charger was plugged into one of those. The issue wasn't that we tripped one of those breakers.
Rather, our at-site sub-panel was being fed from an upstream panel which apparently had a 30A breaker feeding multiple campsites' sub-panels. So the issue wasn't load at our specific site, but rather the combination of the load we were pulling, plus that from the other sites on the same circuit, tripping the 30A breaker. My guess is someone turned their space heater on around midnight when temperatures dropped.
21st Century Truck
Martin
Another great accessory for camping with the Lightning and all its plugs is a portable air fryer. There are several good threads here on the portable air fryer selection and how well they work with the Lightning.
MattVT
Matt
Vermont
We took our Instant Pot with us, and considered taking the Air Fryer Lid too, but decided against it. Ended up not using the Instant Pot at all. We did however use our portable induction stove which was super quick to set up with a camping kettle to make tea and coffee on the tailgate.
Between that and the Ooni pizza oven and Blackstone griddle that our friends had, we were spoiled for choice with cooking options 🙈
SpaceEVDriver
Arizona
We bring our induction stove top on camping/road trips. We also have an electric kettle that goes with the truck. Plus we bring a dual-zone compressor fridge that’s just barely too tall to fit in the frunk. We would like it to fit in the frunk, but we’ve had it for much longer than the truck and there’s just no reason to change it.
MattVT
Matt
Vermont
We were talking about getting an electric kettle just for the truck. Have you found a good storage spot for it? I was hoping to find one small enough to fit in the aftermarket storage system that goes under the rear seats.
SpaceEVDriver
Arizona
We have ours in a camp kitchen box that's easy to take out or put in the frunk.
Farafield
Kim
Vermont
Ford F150 Lightning Flash
Hi, Could you elaborate on this comment? I'm not sure what you're talking about nor why or how to do that. Thanks!
Farafield
Kim
Vermont
I just from a long-er distance trip with my dog and camper. The two charging stints went well. I unhooked once but then realized it wasn't really necessary and opted not to on the way home. I did a lot of research prior and things went acording to plan. I like to camp without hook ups but realized (lightbulb!) that I could power my camper with my truck and so I gave that a try, not super straightforward but help from this forum gave me more insight than the OM. Cool to have that option. Love towing with this truck. Range is reduced roughly by half. Charged at an Electrify America and a Ford dealer both directions.
MattVT
Matt
Vermont
Can I ask what trailer you're towing? Size and weight would be interesting to know!
Farafield
Kim
Vermont
I'm towing a 16' Bambi Airstream which is about 3250 lb.
Sam_oceans
Sam
Calabogie, Ontario
2023 Ford F-150 Lariat Lightning
Yes, we just returned from a 4-day camping trip with our 4,500 pound camping trailer. We consistently got 44 kwh/100km driving between 60 and 75 kph. Also, worth noting, we have a 2023 Lightning Lariat with standard battery pack that we consistently get 22 kwh/100 kph driving around 80 kph. Hills and wind really have a significant impact when driving with a high trailer.
