Can you use FORSCAN and/or FDRS to change BlueCruise settings once it is installed?
2AActuary
Kansas City
2021 F-150 Platinum, Audi R8, Audi S5, Audi Q7,
Without reading the 229 pages in the FORSCAN thread, it is systemically possible to override pre-set maximums within BlueCruise? Specifically, the system kicks off when you hit 81 MPH. I understand the rationale for having a maximum, but in some states - this doesn’t allow for a slight buffer above the set speed limit. Is there a way to set it for like 86 MPH? Asking for a friend.
Mike G
N. AL, USA
I don't think anyone with Bluecruise and FORSCAN skills have investigated that yet. But that 80 MPH limit might just be there due to the fact that your APIM and IPMA etc. may not have sufficient processing power to react any faster than what would be considered safe at 80 MPH.
This is the same APIM that's been used in other Ford vehicles for years. Now with new and improved demands on it's capabilities.
MostlySafeBear
San Francisco, CA
(Eventually) an F-150 Lightning
Not so far, and I for one am glad for that. Slow down! Why would you need a 'buffer' above the speed limit? Between ~6,000 to ~14,000 pounds moving at 80 MPH is plenty fast, fast enough to be instantly lethal to most people that you may collide with.
You're not on the road alone, and your choices affect a LOT of other people's lives. As good of a driver as people may think they are, that doesn't agree with reality. Hundreds of people are killed on our roads every day, and way more are injured for life, and this is despite enormous improvements in safety with newer vehicles.
Has that limit been observed in the Lightning? I haven't see it limit based on speed in our Mach-e. You can set up how you want it to automatically react to speed limit changes (holding a fixed mph above or below), but you an use the steering wheel controls to adjust it after that.
Mike G
N. AL, USA
I guess now I’ll have to try it. ?‍♂
