Texas Dan
With a 10,000 pound towing capacity, one of the big attractions of the F150L is being able to tow a travel trailer or a 5th wheel trailer. Also, with a power output of 9.6 kW and a battery capacity of 131 kWh, the F150L can easily power most RV trailers overnight. But the question begs, can you charge the F150L at the same time the F150L is powering an RV?
At first glance this may seem like a pretty trivial question but I consider it to be rather important. If people do any amount of RVing with the F150L, they are probably going to be spending a considerable amount of time at RV camps. A lot of RV campsites have a 50 amp NEMA 14-50 outlets that can charge the F150L or power the RV trailer but not both at the same time.
People could rent two 50 amp campsites, one for powering the RV and one for charging the F150L, but is it possible to run both off of a single NEMA 14-50? People might think that they would not be able to charge the F150L if the RV was drawing power through the F150L power outlet but RV HVAC units cycle and wouldn't be operating more than half the time. I guess we will just have to wait until people start RVing with the F150L to find out if the F150L will provide power at the same time that it is charging.
