Color of Rear Turn Signals
rdr854
Northern Virginia
18 Volvo V90, 22 Ford F150 Lightning, 23 Outback
On the ICE F-150s, I know that Ford has used amber turn signals for some trim levels and red for others. For those who have seen the F-150 Lightning in person, what color is Ford using for the F-150 LightNing? Is it the same for all trim levels or is it different like the ICE vehicles?
FordTough98198
Domenic
Seattle, WA
2020 Expedition MAX KR, 2022 Lightning (reserved)
Business Consultant
Some of the review videos show it and it’s just solid red.
You can see this video at 4:18 for an example:
2022 Lightning Lariat-ER Max Tow Iconic Silver
rdr854
Northern Virginia
ShirBlackspots
Charles
Wichita Falls, TX
2006 Ford F-150 XLT 5.4L
Current generation F-250/F-350/F-450's, the turn signals are amber
Current generation F-150's, the turn signals are red.
The Maverick, Ranger, Bronco, Explorer, I believe they are amber.
rdr854
Northern Virginia
The F150 appears to be a mix, with some models having red turn signals and others amber. I cannot figure out the breakdown, but the first two trucks that I looked at on the Koons Woodbridge Ford website had a large clear section rather than being solid red.
REDHORSECA
SOCAL
Lightning XLT SR - 5/30 Build, ICE F150 XLT Sold
R&D
Lightning with blinkers on driving by...
VTbuckeye
Joseph
Vermont
19 Bolt, 16 XC90T8, 22 XC40 P8 Recharge, 17 Tacoma
Good catch! I certainly prefer amber to red. There is already a lot of red lighting on the back the lightning.
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
Amber turn signals I prefer over red.
But red has been allowed in the US - mostly to save on costs.
If the Lightning releases in other countries like Europe, they require amber - you can always order a tail light set from Europe...
rdr854
Northern Virginia
Unfortunately, the Euro spec light assembly will most likely not work due or the lack of the required FMVSS rear side reflector and rear side marker light. This issue has come up with some other manufacturers such as Volvo where owners have wanted the rear amber turn signals.
FordTough98198
Domenic
Seattle, WA
Business Consultant
Another example at 5:37
Appears to be an XLT without lightbar across the tail. The “white” area seems to be the backup lamps and you can see the whole red part blinking as the turn signal.
Just prior to the “blinking” you can see brake lights on. The part that blinks is the same as brake light so must be red.
REDHORSECA
SOCAL
R&D
Bunch of tail light action here:
