LightningShow
@Ford Motor Company As of now the only way i can see what rate the truck is charging is by looking at the time it’s predicting to finish charging and then calculating myself what the presumed charge rate is. This is totally unacceptable. Knowing your charge rate is one of the most basic pieces operational information for an EV. Please fix this immediately.
As of now the truck is telling me it will take 29 hours to charge 16% on Level 1. This doesn’t make sense but if i knew what the charge rate was and how much energy the truck is expending then i might be able to make sense of it and decide if i wanted to try another method. But as of now i’m completely in the dark about how the truck is coming up with (now, 31 hours) to charge 20kwh. That’s an indicates it’s charging at well under 1kw. Why? The level 1 chargers i’ve used are typically 1.2-1.5kw. Why does the truck think it’s charging at 0.7kw?
Also, i can’t find anywhere that states the specified output of the ford mobile charger on level 1. Is there a spec sheet? The ford literature i found on the charger doesn’t say much about performance of the charger.
