Firn
23 Pro ER
Following up on my previous post about deconstructing PIDs from Forscan and CarScanner, I’ve been using a long-term monitoring setup to see how my Lightning Pro ER actually behaves under the hood.
The Setup:
  • Hardware: An old phone permanently mounted in the cubby.
  • Software: Torque Pro (logging) + Tasker + Auto-upload to Google Drive.
  • Backend: Raw logs cleaned and ingested into DuckDB using Python scripts.
  • The "Brain": Full disclosure—I used Google Gemini to write the Python scripts and build the dashboards. It’s been virtually hands-off once the automation was set up.
Here are the findings from the data so far:
1. Performance vs. State of Charge (SOC)
A common question is whether the truck limits current as the SOC drops.
Current: Looking at the data, the answer appears to be no. Maximum current remains remarkably consistent even as SOC decreases.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769915282367-gq
Power: While current stays steady, total power does drop slightly as SOC falls. This is the expected result of voltage sag as the battery depletes.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769915448700-4
2. Acceleration & Speed
We know acceleration feel tapers off at higher speeds, and the data confirms why:
Wind Resistance: Obviously, the "brick" shape of the truck plays a role.
Current Limiting: The data shows the truck actively tapers current once you cross approximately 60 mph. You can see the clear "roll-off" in the current chart at the top end of the speed range.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769915589993-5q
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769915697290-uc
3. Battery Capacity & Temperature Effects
Does temperature affect stored energy? Yes, but the way Ford displays it is the real story.
Energy per 1% SOC: My analysis shows there is more energy per 1% of battery at higher SOCs than at lower ones (the scale isn't perfectly linear).
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769916399821-wt
The "Cold" Manipulation: When looking at energy by SOC colored by temperature, you can see how cold weather affects the pack. More specifically, it shows how Ford's BMS manipulates the displayed SOC to show a "higher" percentage for a given amount of raw energy when temps drop.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769916537460-dz
4. Aerodynamics & Efficiency
I attempted to correlate average power by speed and temperature. While the speed/temp data is interesting, trying to isolate the effects of wind speed and direction on efficiency has been difficult—the data is still a bit too noisy to draw a "smoking gun" conclusion there.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769916141473-p9
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769915986048-e2
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769916073695-d2
Sadly attempts to determine the effects of wind speed and direction on efficiency are not as clear.
5. Tire Pressure (TPMS)
I tried to quantify the efficiency gains of higher tire pressure.
The Verdict: My data (and separate controlled tests) suggests that tire pressure has a negligible effect on overall efficiency in this platform.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769916945077-wt
6. The "Secret" Drive Map
One of the coolest features of the DuckDB setup is the ability to generate a GPS heat map of every drive. I can color the map by any metric—kiloWatts used, motor temp, or speed. (I’m keeping the map private for obvious reasons, but the visualization is a game-changer for spotting efficiency "black holes" on my daily routes!)
I want to be clear—I didn’t manually write the code for this. I used Google Gemini as my lead engineer to build the entire backend. If you’ve been sitting on piles of CSV logs but don't know Python or SQL, this is the way to do it.
What the AI handled:
  • Python Automation: Gemini wrote the scripts that monitor my Google Drive, grab the raw Torque CSVs, and handle the "cleaning" (fixing timestamps, removing nulls, and filtering out GPS glitches).
  • The Database (DuckDB): It devised the logic to ingest that data into DuckDB, creating a high-performance local database that makes querying months of driving data nearly instant.
  • The Dashboard Logic: It wrote the Streamlit and Python code to generate the actual charts and performance visuals, including the logic to calculate "Energy per 1% SOC."
  • The Workflow: It even helped me set up the .bat files and Tasker triggers so the whole pipeline runs with a single click (or no clicks at all).
The barrier to entry for this kind of "Big Data" analysis on our trucks is gone. I just described what I wanted the data to show, and the AI provided the syntax to make it happen.
mr.Magoo
2022 Lariat ER, AMB
I think it would be helpful for the rest of us who is doing some data collection to see what values you're looking at.
Plus It would probably be more relevant to look at commanded torque (instead of amps) vs. speed vs. throttle position unless you drive your truck strictly digital (ie, all or nothing).
Firn
Firn
23 Pro ER
Lots of ways to mix and match the data, this is certainly just the first go at it.
In this case my primary interest was in the current capabilities as that is likely to be the biggest limiting factor of the Lightnings design. Specifically where does Ford set the limit and how do they enforce it.
Torque vs speed vs throttle position (torque, not torque commanded)
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1769954090328-1a
Firn
Firn
23 Pro ER
The data pipeline would be interesting as well
Front end is pretty easy.
Old Android phone mounted in the cubby. It where I can see it if needed, but it's mounted on the front wall of the cubby so it's out of the way.
The android app Tasker opens the logging app once the phone gets power, and sends it to the home screen when power is stopped so that the phone can naturally sleep.
For logging (and as a dashboard) I use Torque, specifically because it makes well structured CSV files directly, no export or cleanup required.
From there I use an app (can't remember the name, I just googled something) that automatically syncs to my Google drive when the phone connects to my wifi.
After that I use Google Drive for Desktop with the sync for offline enabled and the script pull from the "G" drive for bringing into the Database.
The rest is scripts for ingestion, cleanup, etc. Then of course the dashboards.
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
Awesome!
Firn
Firn
23 Pro ER
Did some more work into the dashboards and data.
Also had Gemini switch to Plotly as a plotting tool and I revamped the structure some while also making new plots.
This plot is looking into the difference between SOC and SOC Displayed. A one to one match would be along the solid white line.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1770340127210-ax
This next plot dives into how much energy is in each 1% of SOC displayed. Ideal is 1.31 (for my ER) for each percent. By coloring the dots by temp we can see how temp changes the amount of energy in the pack. Interesting is what looks to be a subtle trend down to the left.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1770340214416-y3
Providing a look into how fast energy is drained from the pack at various speeds.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1770340443593-kx
This one is fun, regen energy by speed and deceleration. We can see that as speed increases the truck increases the rate of regen yet the deceleration rate stays the same. Fairly obvious, but fun to see the data.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1770340518760-4h
Diving into the battery, I plotted cell variation over time. Red is max deviation, green is average deviation. This will give an indication of battery issues or trends towards a cell mismatch.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1770340726828-f2
Looking more into cell variation I dove into when the most deviation happens. This breaks deviation down by different states. Driving appears to be where the deviation is appearing, with charging and resting reducing the deviation.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1770340852644-yc
Next I looked into passive balancing. We know the pack does top balancing, working to bring the balance lower as it reaches 100%. Instead I wanted to look and see how the pack may be performing balancing while it is resting. This analyzed the cell variation before and after resting periods (periods when the truck was off only). From this it appears that the pack is actively balancing during resting periods.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1770341036023-2z
This last one was the most interesting to me.
There has been frequent discussions as to the effects of "flooring it" on efficiency. To that end the following plot shows (electrical) energy consumed with (mechanical) energy gained. Using motor speed, drive ratio (rpm per mph) and vehicle weight for the kinetic energy; as well as current and voltage for electrical power. From there the color indicates the accelerate rate as determined by the accelerometer on the phone.
Dots clustered closer to the dashed line indicate higher efficiency (kinetic energy gained is closer to electrical energy consumed). Dots further below the line indicate more electrical energy consumed than kinetic energy gained.
The solid colored lines are the trend lines for the acceleration rates.
I'll see if anyone else gets it, but I spent some time on this trying to figure out what is happening.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1770341519439-cx
Wattsgas
MIke
Brinnon, WA
I find the percent of charge vs the stored energy interesting. It doesn't look like you ever have the 1.31 kw per percent. Also looks like percent vs kw gets less the lower the percentage of charge. It may explain the optimism of displayed range when at 100% and the more pessimistic range at 40% that many people have experienced. I am a little surprised that a 100% battery pack at 70 degrees wouldn't have 131kw of energy.
Firn
Firn
23 Pro ER
Agreed
Although I do rarely charge to 100% and even more rarely log while charging. I do know I have seen 131kwh displayed at 100% charge so it's just not in this data.
Which is worth pointing out. This data is only since August, so its mostly cold weather data
mr.Magoo
2022 Lariat ER, AMB
Agreed
I suspect it might be an averaging issue too ?
Since you don't mention which parameters you're looking at, I have to make some assumptions, and that is that you're looking at BATT_CHAR_SOC (actual) and BAT_TO_EMPTY_ESTIM (ated), if not let me know what you're looking at and I can compare.
The chart below is from a drive to Chicao last years, charged overnight to 100% (displayed),
drove, fast charged, and continued to drive...
If I simply take the (keyword: estimated) estimated capacity and divide it by SOC, it'll reflect the full pack size of 142kW repeatedly though the years.
Ford F-150 Lightning Deep-Dive: Lightning Pro ER Performance & Efficiency via Custom PID Logging 1770385571954-yc
Firn
Firn
23 Pro ER
One of the dangers of using tools like Gemini to do this work is that it isn't as apparent exactly what is going on in the back end. It's possible it's using SOC and not SOC displayed but I don't believe it is.
The same is true for the averaging, you don't really see "under the hood", well not unless you can read, and do read, the actual code. As this is still in testing i have not validated each and every function. Is also just for fun and trend/pattern visualization.
Of the two charts relating energy to SOC the first (in my first post) does appear to hit or just tick over 130, it also looks like the temps may have been below 70f for much, if not all, the time it was above 90%. In the chart that shows how many kwh per each 1% of battery the data is either below 100% SOC or is quite cold.
Ultimately I rarely charge to 100%, and very likely have only done so with the battery cold, or at least below 60f. At least for these logs.
