Literider150
- First Name
- Brad
- Sep 8, 2024
- 67 Deer Trail
- 2024 F150 Lightning
- Occupation
- retired
After leasing this truck about almost two years some of the default settings on both the Pro Power feature and the charging power system would be much better if you could turn them off manually; or change them. For example, I have an electric portable refrigerator. I know I have to go to the Pro-Power section then press the button that says *stay on when truck is turned off*. That seems to work but it seems like so many things can change that. It can be ON using the power outlet in the front when I go into the store, then when I come back it's off. I've tried it several times. I know once I had to go back and unlock the truck and get in then leave and lock it again. It doesn't seem like that should take that set position of "*stay on* to turn off after 30 seconds or whatever. I guess you have to check the screen every time you even come close to the truck in case something changed and the pro power to the cab went off.
I believe I figured out that the cab pro power setting doesn't work for the outlet in the back. The AC one. If you read the directions closely it doesn't really say you're leaving the power on to all the outlets; just the front ones. So my fridge has a DC plug and an AC plug. I think I've tried it about half dozen times and it's always off when I come back after about 30 min. or so. What am I doing wrong? I know the power limit - another default thing that has to be constantly changed (it won't save the last setting) - is set high enough; plenty of battery. Actually, I guess that default does get saved.. I think.
Also, with all the talk about not charging to 100% all the time, why does the manufacture make the default AC charging limit 100% unless you make a one time limit. Seems like it should save the last limit you put in.
Anyway, don't get me wrong. I love this truck and if I could finance it I think I would buy it. Already bought a tonneau cover for it and some other things.
