Door Seals Issue - Water Leak on Driver's Rear Door
elkniks
Seaside, CA
2023 Lightning
I have seen the posts on the wind noise (I have it also on drivers door) but does anyone have water leaks? I am noticing water in the drivers rear door sill after washing the truck. The truck is only two months old and I have noticed water every time I wash it.
My biggest concern is finding a dealership service department that is not horrible.
Ford Motor Company
Official Ford Account
F-150 Lightning
sheldengildon
USA Austin
ford f150
If the door seals on your driver’s rear door aren’t sealing properly, you’re probably looking at replacing or adjusting them. Over time, seals can wear out or get misaligned, which lets water sneak in. First, check if the seals are cracked or torn. If they look okay, try cleaning them and applying some rubber conditioner to soften them. Sometimes, that helps restore their flexibility. If it’s still leaking, you might need to replace them altogether. I’d recommend checking out Mantaline for replacement seals—they’ve got good quality options for most vehicles. It’s also worth ensuring the door isn’t misaligned, as that can cause issues too.
