Nightshade
- First Name
- Aidan
- Sep 4, 2021
- Alberta, Canada
- '22 Ford F-150 Lariat | '22 Ford F-350 S/D Tremor
- Occupation
- Sup/t. Wildland Firefighter with Alberta Wildfire
Ever wondered if you or a passenger wants to input the address while driving on the Ford Navigation screen but turns out you can't as Ford locked you out while the vehicle is in motion? Well thanks to @Livnitup, we finally can enable this feature! By using FORScan, you can enable this by changing the following steps and as ALWAYS, make a backup of the APIM module before attempting ANY changes so you can revert back to factory when needed:
APIM: 7D0-03-01 -> 5753 - xxx - xx-- (change only the bolded numbers only, leave the "x" alone).
Once you have changed this, you will see it will get a little glitchy at first 2-3 times of cycling on and off. Cycle the truck 3-5 times or until it goes back to normal and you're good to go; this is the only time you have to do this. You can now use the factory navigation screen keyboard while moving. Note; not all trucks will need to cycle more than 5 times. You can also do a hard reboot about 1-2 times if needed but not necessary. Press and hold the POWER button and the ">>" button together for a few seconds, let the APIM and screen reboot to splash screen then let go; you should be good to go.
*do at own risk.
This mod currently works on the following models as of this posting:
-'21 and '22 F-150 XLT
-'21 and '22 F-150 Lariat
-'21 F-150 Platinum
*do at own risk.
-'21 F-150 Platinum
