AK | 100% |
AL | 100% |
AR | 100% |
AZ | 25% |
CA | 63% |
CO | 50% |
CT | 60% |
FL | 32% |
GA | 67% |
IA | 33% |
ID | 33% |
IL | 56% |
IN | 40% |
KS | 50% |
KY | 75% |
LA | 33% |
MA | 61% |
MD | 53% |
ME | 83% |
MI | 56% |
MN | 80% |
MO | 100% |
MS | 0% |
NC | 33% |
ND | 0% |
NE | 50% |
NH | 60% |
NJ | 57% |
NV | 100% |
NY | 54% |
OH | 55% |
OK | 33% |
OR | 50% |
PA | 86% |
RI | 40% |
SC | 50% |
SD | 0% |
TN | 88% |
TX | 63% |
UT | 33% |
VA | 50% |
VT | 60% |
WA | 67% |
WI | 25% |
Agate Black Metallic | 60% |
Antimatter Blue Metallic | 54% |
Atlas Blue Metallic | 60% |
Carbonized Gray Metallic | 51% |
Iced Blue Silver Metallic | 60% |
Iconic Silver Metallic | 55% |
Oxford White | 40% |
Rapid Red Metallic | 50% |
Smoked Quartz Metallic | 62% |
Star White Metallic | 73% |
Stone Gray Metallic | 50% |
….and I thought I was highly analyticMany of the data points that have high % of build dates, also have a small number, so should not be used as a indicator.
Here are a few observations:
- Wave % reduces a wave number gets higher, with Wave 3 being an outlier with little data. So the older your order, the more likely you are to have a build date.
- Priority is likely irrelevant unless you compare reservations to order conversion by reservation date (not this spreadsheet).
- Location does not anything that strands out to me, other than half of the 44 states in the spreadsheet have 5 or fewer orders.
- Trim is interesting, with Lariat making up 67% of orders (per Ford's push), and also having the largest % of estimated build dates @ 61%. One would expect to be the smallest.
- Color has two low number entries (Oxford White & Stone Gray Metallic), with the rest being a healthy amount each. The stand out here is Star White Metallic @ 73%.
- Battery is as I expected, with ER having a higher build date, as well as highest uptake.
- Package also had a standout in that selecting both tow packages has 68% with build dates.
If you had an early invitation and ordered a Lariat ER in Star White Metallic with both tow packages you very likely have a build date
