Rando
I’ve seen the test of the PRO SR making it 213 miles 100%-0% battery @ 70 MPH in moderate weather, not much elevation change, and no battery degradation. I haven’t found much concrete information on the range or efficiency at a flat 65 MPH or 60 MPH in favorable weather.
I live in SW Missouri where there are almost no DCFC once you leave the I44 corridor. I’m trying to estimate where I would be able to take the truck should I get the opportunity to buy a SR PRO. Fortunately, most of our highways are between 60 and 65 MPH speed limits.
Also, what number is everyone using for Wh/mi @65 in A Better Route Planner? It defaults to 596 when I select a SR PRO to play around with which seems pretty poor given people are reporting 2.1-2.2 @ 70. If I did my math right, 596 Wh/mi would be 1.67 Kw/m.
