FCSP charging issue again
BSull
Robert
Mesa, AZ
23-F150 Lariat ER, 17-Mercedes GLC300, 19-Vette Grand Sport vert
Charged last night with truck target charge set to 85%, FCSP dial on #7, FordPass set to target of 85%. Target charge time started @ 11PM. Went to the truck this morning and charge was only 75%. I couldn’t find any faults, the light on the FCSP was the standby blue, truck did not have any faults.
Has anyone had something like this happen? If so, what was the issue if you ever found out.
Maybe once .... it happened to me, in my situation an OTA install interrupted my charging session mid-course, I had to manually start the charge after noticing the situation.
BSull
Robert
Mesa, AZ
Last update I had was Sep 3. Don't think that's the issue. thanks for the suggestion.
I updated mine from 90% to 70% target last night, about 30min before it was scheduled to charge. No problems. I do recall a time or two where I woke up with less than expected but I can't remember if it was an OTA or if I ever figured out why. They where one off and haven't had it happen in quite a while.
One time something like that happened to me.
I had set it to start charging 5 minutes from the current time using the truck menu, and I went back to check about 10 minutes later and it hadn't started charging.
So I went back into the menu and set it again.
I was using either the one-time charge or the location charge sub-menu, not sure which, but after I reset the specs, it started and charged as specified.
Anyway, now I check to be sure the truck charging has actually started as scheduled in case I made an error or the software settings didn't take, and so far it always has.
