Ford Charging Station Pro or Emporia Charger
026TB4U
2021 Powerboost, 2022 Mach-e
Hi all,
I just bought a 2024 used lightning and need some advise on which charger to choose. I found a used Ford Charging Station Pro for $500. I'm trying to decide between that or a new Emporia at $429.
Please share your thoughts on either charger and which I should buy.
SpaceEVDriver
Arizona
I have both the FCSP and the Emporia Pro. I prefer the Emporia Pro despite the frustrations I’ve had getting it to properly talk to my solar system to only charge when we have excess solar. Still working on that.
B177y
Bill
Oly Pen, WA
2024 Pro ER Max Tow
If you have the capacity in your electrical service and NEED 80 amp charging, go with the Ford.
Otherwise, I'd go with the Emporia.
EDIT:
Since you have a 2024, you can't even use the 80 amp unless you have the Pro trim with the 80 amp option. Just get the Emporia.
026TB4U
EDIT:
Didn't know that. Why did Ford remove from the 2024?
astrand1
Alex
Studio truck driver
I’ve 2 emporia chargers. Check their direct site. They sell “refurbished” models there. Same warranty as new. And quite a bit cheaper. Both of mine are supposed refurbished but they looked new when I opened the boxes and have been working great. So easy to change settings on the app.
Heliian
I think also that the need for the average user to go over 48a wasn't there.
It was good in theory, especially if the v2h system had worked. However, it didn't. Also it's lighter.
Phineas Magliozzi
Bay Area
2023 Lightning XLT SR
If you have solar, it's a no-brainer. Emporia's "Excess Solar" feature is crucial. You do need some variant of their Vue system as well to determine if there is excess solar available. No direct connection to anything solar, just monitors the mains and determines if there is sufficient power going back to the utility to warrant turning on the Emporia. The threshold is 6a, so about 1.4kW at 240VAC. Once on in will ramp up and down (or off) to keep the power going back to the Utility to a minimum. You can, of course, just charge at any (6 to 48) amperage you would like as well. As you can probably tell, I like mine.
RLXXI
S. E. Louisiana
Automotive Technician
EDIT:
Can use it, just won't get the full 80a charge, my FCSP charges at 48a
RLXXI
S. E. Louisiana
24 and 25 dropped the extra charger/inverter, cost cutting measure.. I also have the FCSP and it can still charge 80a, the truck will only pull 48a from it.
RLXXI
S. E. Louisiana
Have you looked into Home Assistant? Might be an MQTT or other way to allow coms between the units. Good chance you'll need Ford's API if you can get it.
TomAHawk
F150 Lightning
Robot technician
I have the Emporia Pro and the Vue system. I was able to link it to my solar system and it used to charge with excess solar but Emporia changed the way their app works and it hasn't charged with excess solar for about 6 months now. But it's still a nice system. I'm sure if I want to spend a bunch of time on the phone with Emporia tech support they can get it set up again but I'm not that worried about it since my electricity rates are around 10 cents per kilowatt hour. Emporia tech support reps are pretty helpful if you want to go that route.
I have owned and used both for at least a year each. Although I have 80-amp capable truck, I only installed a 60A breaker - so 48A charging.
Switching from the overly-bulky, Wifi-dropping FCSP to the Emporia was one of the best things I did. With a 2024 that can only do 48A, Emporia is a no-brainer. The cable and charge head are so much smaller, lighter and maneuverable. Since the FCSP has the CCS1 head instead of the J1772, I felt like I was DC fast-charging every time I plugged in.
flyct
Jerry
South Florida
Blissfully Retired
Hi all,
To choose between the 2 I'd absolutely choose the Emporia. It has a standard J1772 plug that can charge most any other brand than Tesla. The Ford Charge Station Pro plug to car will not be able to charger a J1772 or Tesla car. Tesla's come with a J1772 to Tesla NACS adaptor that will work with the Emporia of ANY other EVSE with a J1772 plug except the Ford Charge Station pro.
Eventually all new EVs will come with a Tesla NACS.
But the gold standard in my opinion is a Tesla Universal Wall Connector EVSE. I have one at our house and another at our cabin.
WXman
Central Kentucky
www.facebook.com
2025 F-150 Lightning Flash
Meteorology/Transportation
Ford sent me the Emporia 48 amp system as a part of the Power Promise promotion. It's been perfect so far. I really like it, and the app on my phone is fantastic.
The electricians that installed it were with Qmerit, which is the contractor Ford chose to carry out Power Promise installations, so they've done a lot of them. They told me that the 80 amp systems they install usually end up with problems and issues, so they are really trying to get away from those and stick with 60 amp installations or less. Much fewer issues they said.
