Front Trunk Won't Close (weird failure mode)
ctuan13
Chuck
Pittsburgh, PA
Well it's like the title says, my hood stopped closing on its own. (I can obviously still manually guide it down and push it closed) But here's the weirdest part, it will open just fine on its own, but refuses to close.
So I first tried a 12V reset(disconnecting and reconnecting the 12V battery), but that didn't solve the problem. So then I took my high level scanner and scanned it to see if there were any codes. Other than the hidden codes related to my TCU being disconnected and the errors thrown when the 12V battery was disconnected, there was only one, unknown code, but it stuck out like a sore thumb:
Under the BCM #1 (Body Control Module) there was code B1305:01 HOOD SWITCH.
I tried erasing the BCM codes, but this did nothing.
From my research this isn't related to the pressure switches along the tops of the fenders inside where the hood closes, this is related directly to the latch.
Unfortunately, or rather fortunately, I had to turn around on my cross-country road trip due to a leaking vent fan in my teardrop camper. I was able to score an appointment at my Ford dealer and I'm waiting to see what they say now.
I'd have gone and replaced the latch myself if I could, but I figured since I'll be back for at least a week, I'll just have them do it since it should be covered under warranty.
Have any of you ever experienced this failure mode? I'll be sure to keep you guys updated.
Heliian
I would have also tried the frunk height reset.
There have been a couple reports of bad latches.
As @Heliian mentions we've seen a few reports of failed lift/closer mechanisms and a latch or two, hope they get it diagnosed and fixed for you quickly!
Athrun88
Toronto, Ontario, Canada
Had a similar issue where the frunk would open but refuse to close and would beep at me. Fix was easy, noted it wasn't opening all the way for some reason, never set a manual height or anything. Pushed the frunk all the way up until max height, then hit the button to close and it closed. No issues since then, seems like it was a one-off situation. May or may not apply to you, but could be worth giving a try.
ctuan13
ctuan13
Chuck
Pittsburgh, PA
Oh I forgot to mention, I tried that too!
Rtashiro
Ryan
Winnipeg, MB, Canada
F150 lightning lariat, Mustang MachE
I had a similar situation where it would not close and latch all the way. I then could not open it either and since it was not fully latched it would scream at me if I was driving. Took it to the dealer and they fixed it not sure what they said but I believe it was a software fix and not a hardware issue.
ctuan13
ctuan13
Chuck
Pittsburgh, PA
UPDATE: Well I finally got my truck back, the answer they gave me as to how they "solved" isn't super confidence inspiring...
Basically it was throwing codes for the squeeze sensors that sit on top of the fenders that allow the trunk module to detect closing pressure. Well he tested the sensors for continuity and they supposedly tested good as did the wiring for loose or intermittent connectivity.
He then disconnected and reconnected the main harness connectors for the gateway module and the front trunk module and it began working. He said it was probably just a loose connection in the connector.
I know these things happen, but this isn't giving me the warm and fuzzies right before my cross country road trip ?
There have been other incidents of poorly seated connectors which eventually wiggle appart.
ctuan13
ctuan13
Chuck
Pittsburgh, PA
UPDATE:
Well as of two days ago, the trunk on my Lightning is once again malfunctioning. It's the same failure mode of opening fine, but not closing. It worked fine for about a week and then it seemed the first good rain I drove through, it failed again, but I can't be sure if its the rain.
The more time passes, the more I suspect it could be the hood latch switch. Although, this time no code was set and the BCM reported normal function. However it could also be the module as that was suspected almost two years ago when it first malfunctioned.
I can't get a service appointment until Friday, so I'll keep you posted!
It does seem though for this and a variety of other reasons, I will be going with a different tow vehicle for this summer's cross-country road trip.
21st Century Truck
Martin
Yikes! Please do keep us posted.
We are taking our teardrop trailer on a cross country trip as well, starting around 01 July, so any frunk problems information will be of high interest.
ctuan13
ctuan13
Chuck
Pittsburgh, PA
Will do!
Definitely would be a pain in the ass to deal with on a cross country trip. I get that I could just manually close the trunk manually every time, but I'd rather not have to force those motors down so often considering I access the trunk often!
ctuan13
ctuan13
Chuck
Pittsburgh, PA
Where are ya headed?
21st Century Truck
Martin
Oh, six weeks of Great Adventure from Virginia to Glacier National Park, the Grand Canyon's North Rim, and many many points and friends' houses and their washing machines in between.
No set route - we'll discuss and adjust every 3 - 4 days over the National Geographic Adventure Atlas laid out on a picnic table.
This is a 2-person trip... myself and a 14-year old (grand)nephew from Europe. I'm the driver (er... mostly, haha) and he's the camp cook. A bit of a self-discovery and independence-building adventure, far from parents etc.
Two years ago, I did a six-week Great Adventure trip with his cousin who's now 16 and with whom I'm still friends to this day after that epic Summer trip in my old Mach E. Naturally, the younger set on that side of the Pond all lined up on the boy's return... I had two 10-year olds this past Summer for 4 weeks in the Mid-Atlantic, and we "Lightning-proofed" the teardrop along with a topside platform tent on the beaches and in the mountains.
ctuan13
ctuan13
Chuck
Pittsburgh, PA
That sounds like fun! Well definitely document your travels, I dont know about everyone else, but I'm certainly interested in how it goes for you as I did the cross country towing thing with my Lightning last summer.
21st Century Truck
Martin
As long as we (again) avoid the DC Fast charging near-desert of West Virginia :rolleyes:, we'll have a grand trip.
I'd be looking for Your Lightning + teardrop on the open road, except... Your Lightning won't roll on Your trip, eh?
