Hot shower system for the frunk?
MM in SouthTX
2022 Lightning Lariat
I want to install a hot shower system in the frunk for winter surf sessions. A demand pump like this one and an inline heater could send water from an ice chest or bladder to a shower head. Problem is I can't find an inline water heater with energy demand lower than the 2.4kW that the frunk power outlets provide. Anyone thought about doing this and found a good solution?
Blainestang
FL
F56, R55, Pro
Given the limited power, it might not be feasible to heat the water enough in a single pass, so maybe something like this that takes a little time to heat a tank of water, then you use it.
https://www.homedepot.com/p/Rheem-M...G7x8V7E88yG8S09qvNxoCjI8QAvD_BwE&gclsrc=aw.ds
MM in SouthTX
lightspeed
2023 Lightning Lariat ER
MM in SouthTX
Whammy Bar
1971 F100 + 2022⚡Lariat ER
You're going to want 2, ideally 3 gallons per minute flow rate. Assuming a winter water temp of around 50°, you're looking at needing a 50° rise. A 120 volt unit will be lucky to give you half a gallon a minute.
Your best bet is to run a cord back to the back to utilize the 240v power and pair that with a 7.2kW max heater.
Or, preheat the water and just use a small pump to pressurize it.
TLDR, it takes a huge amount of energy to heat water.
MM in SouthTX
Thanks. I am learning that. I currently throw hot bottles in an ice chest and pour them over my head when I get out of the water. Maybe I will stick with that, or buy the RinseKit with the heat stick. They told me they will be making a 120V version soon.
Whammy Bar
You could hack something together, like a 5 gallon jug, a 120v immersion heater, and a dispenser pump connected to a shower head... It'd take 15 minutes to heat up (which I'm guessing is 14 minutes too long) and would be clunky.
You could also leave the truck on to keep prob power on, and add a temp controller to regulate the immersion heater. Now you basically have a full bore hot water heater in the truck. But it's gonna be more plug and pray than plug and play.
Just spitballing ideas.
Firestop
Firestop
MM in SouthTX
Yep. We have an Anova sous vide heat stick. Hang it on the side of an ice chest. Use a demand pump with a pickup hose in the ice chest. Leave the truck on while I surf. That would work!
GarageMahal
JT
2003 Mercury Marauder; 2023 Lightning XLT SR
Geek
Starting with hot water will help a lot too. Maintaining temp is much easier than heating.
dirtdiver
Steven
San Diego
You should develop something and sell it! Plenty of surfers have money (at least out here in San Diego) and electric cars are more and more common. I think if you were looking for a product that would work across many vehicles you would need something to work on 120v and 1KW. As others have pointed out would push you towards a heated tank. But that is not an all bad solution. Plug it in prior to a surf session and have 5 gallons ready when you get out in an hour...
