How common is this?
Boatman
F250 for now
Below is listed all the issues with a 2022 Lightning I am considering buying. Are issues with these trucks common? or is this just bad luck for the last guy. Selling for a good price but it's history worries me. Maybe a 2023 would be a better buy.
GSAR Claim KeyTrx CodeTime In ServiceLabor HoursDealershipDIST (Miles)Repair DatePrefixBaseSuffixDoc
Details92064222C1520.3ENGLEWOOD FORD7103-AUG-2022***05343901
Customer Comments22C15 RECONFIGURE THE BODY CONTROL MODULE WITH UPDATED AS-BUILT DATA
Tech CommentsRECONFIGURED THE BCM PER FSA 22C15
Details244295822P089071011-FEB-2023*14G650*85238301
Customer CommentsFLARE-PRD-SOFTWARE-FNV2-657018-933871
Tech CommentsFLARE-PRD-SOFTWARE-FNV2-657018-933871
Details247454322S7190.7FORD OF PORT RICHEY89914-FEB-2023***39235201
Customer CommentsRECALL 22S71 WINDSHIELD WIPER MOTOR REPLACEMENT
Tech CommentsINSPECT AND REPLACE WIPER MOTOR
Details259381622C1590195026-FEB-2023*14C636*85284801
Customer CommentsFLARE-PRD-SOFTWARE-FNV2-641174-955197
Tech CommentsFLARE-PRD-SOFTWARE-FNV2-641174-955197
Details28989251101FORD OF PORT RICHEY310106-MAR-2023*3504*39390703
Customer CommentsCUSTOMER STATES PRE COLLISION ASSIST NOT AVAILABLE LIGHT CAME ON CHECK AND ADVISE
Tech CommentsIPMA B1385:68 PINPOINT BK1 Y BK2 N REPROGRAMMED PSCM CMR B15E1:97 PINPOINT D1 N NO WARNING MESSAGES IN 18 MILE ROAD TEST LANE KEEPING WORKS AS DESIGNED
Details29093291101.5FORD OF PORT RICHEY310106-MAR-2023*14G617*39390701
Customer CommentsMESSAGE CAME ON DISPLAY SCREEN SAYING POWERTRAIN MALFUNCTION REDUCED POWER FAULT DETECTED CHECK AND ADVISE
Tech CommentsNO POWERTRAIN RELATED DTCS STORED ROAD TEST 18 MILES UNABLE TO DUPLICATE RETRIEVED CODE STORED IN RFA U3000:49 PINPOINT H1 N REPROGRAMMED RFA
Details3665485E83132.1FORD OF PORT RICHEY1355012-JUN-2023*10B689*40198301
Customer CommentsCUSTOMER STATES FAST CHARGERS DO NOT CHARGE VEHICLE AND BLINK YELLOW-SLOW CHARGER WORKS FINE. AND WHEN CHARGING WITH 50KW PRO CHARGER IT WILL NOT CHARGE VEHICLE....KILOWATT PER MILE IS ALSO LOW CUSTOMER USED TO GET 350MI AND WILL NOW GET 300MI CHECK AND ADVISE
Tech CommentsOBCC P1A3C:00 SOBDM P0CF7:66 PPT BB1 N BB2 NO ACCESS TO DC FAST CHARGER PPT C1 Y EVSE FAULT REPROGRAMMED PCM BECM ABS SOBDM SOBDMC SOBDMB GFM2 PER 22- 2495 CHARGED VEHICLE WITH 32A LEVEL 2 CHARGER TO 90% DTE READS 300 MILES
Details3838439E83130.2FORD OF PORT RICHEY1432321-JUN-2023LJ9Z10B706J40271301
Customer CommentsCUSTOMER STATES FAST CHARGERS DO NOT STAY CHARGING AND BLINK YELLOW- AND WILL HAVE RED RING AROUND CHARGING PORT-SLOW CHARGER DOES SAME THING-HAPPENS INTERMITTENTLY WITH ANY CHARGER CUSTOMER HAS NUMEROUS CHARGING FAULT NOTIFICATIONS ON FORD PASS CHECK AND ADVISE
Tech CommentsNO ACCESS TO FAST CHARGER SOBDM P0CF7:66 PINPOINT C1 Y SET BY EVSE TEST DROVE VEHICLE TO GET BATTERY CHARGE LIFE DOWN=CHARGED TO 100% EVERY TIME-NO FAULTS PROVIDED CUSTOMER WITH NEW ev CHARGER TO ASSIST IN TROUBLE SHOOTING CHARGING CONCERNS.
Details4067834E83142.2FORD OF PORT RICHEY1736125-JUL-2023*14G371*40545901
Customer CommentsCUSTOMER STATES OVER THE AIR UPDATE WILL NOT GO THROUGH CHECK AND ADVISE
Tech CommentsOTA DASHBOARD SHOWS "UPDATE ACTIVATION" BATTERY SOC IS 92% PER BCM (12V). PINPOINT B1 Y B2 N PERFORM ALL AVAILABLE MODULE UPDATES WITH FDRS FOR GWM APIM TCU SHOW PROVISIONED
Details4067867PRENT140FORD OF PORT RICHEY1736125-JUL-2023*RENTAL*40545905
Customer CommentsCUSTOMER REQUEST RENTAL TRANSPORTATION.
Tech CommentsAS NEEDED.... RENTAL TRANSPORTATION PROVIDED
Details5101228E83175.5FORD OF PORT RICHEY2628516-OCT-2023*10654*41195905
Customer CommentsCUSTOMER STATES SYNC SOFTWARE UPDATE WILL NOT GO THROUGH WHEN TRYING TO CHARGE OVER NIGHT IT WILL SAY UPDATE FAILED CHECK AND ADVISE
Tech CommentsTOUCHSCREEN SHOWS UPDATE READY ATTEMPT TO UPDATE AND DOES NOT PER OTA DASHBOARD BATTERY SOC TOO LOW BCM DATALOGGER SHOWS SOC AT 79% FOUND MULTIPLE REPORTS ON HOTLINE SELF HELP FOR UPDATES FAILING DUE TO LOW SOC WITH BATTERY PASSING LOAD TEST REPLACED BATTERY RESET BMS LET SIT OVER NIGHT TOUCHSCREEN DISPLAYS UPDATE COMPLETE APIM UPDATE CANCELED UPDATE APIM WITH FDRS THEN UPDATE GWM AND ANOTHER APIM UPDATE IS AVAILABLE PERFORM SECOND UPDATE OF APIM VEHICLE SHOWS NO UPDATES AVAILABLE ON TOUCHSCREEN
Details5183575E84171.3FORD OF PORT RICHEY2628516-OCT-2023*NPF*41195908
Customer CommentsCUSTOMER STATES WHEN PRESSING AUTO BUTTON FOR AC AND HEAT THE FIRST OPTION IS NORMAL AND SECOND OPTION IS FULL POWER AND 3RD OPTION IS MEDIUM OR LOW CHECK AND ADVISE
Tech CommentsNO HVAC OR APIM DTCS COMPARED TO ANOTHER 22 LIGHTNING AND AUTO BUTTON FUNCTIONS THE SAME POSSIBLE REDESIGN OR SOFTWARE PROBLEM NO REPAIR AT THIS TIME
Details507557923S30171FORD OF PORT RICHEY2628516-OCT-2023***41195903
Customer CommentsRECALL 23S30 REAR LIGHTBAR REPLACEMENT
Tech CommentsAS PER RECALL REPLACED LIGHTBAR COMPLETED
Details506619023B11170.2FORD OF PORT RICHEY2628516-OCT-2023*78045G34*41195902
Customer CommentsRECALL 23B11 INSTALL NEW DASH MAT
Tech CommentsAS PER RECALL COMPLETED REPLACED DASH MAT
Details508206723B57170.6FORD OF PORT RICHEY2628516-OCT-2023*10D672*41195904
Customer CommentsRECALL 23B57 HIGH VOLTAGE BATTERY MODULE REPLACEMENT ANDOR BATTERY ENERGY CONTROL MODULE BECM SOFTWARE UPDATE
Tech CommentsAS PER RECALL UPDATED BECM COMPLETED
Details5066370E84173.1FORD OF PORT RICHEY2628516-OCT-2023AL1Z7G273A41195901
Customer CommentsCUSTOMER STATES THERE IS A TICKING POP NOISE COMING FROM WHEEL AREA WHEN IN REVERSE AND WHEN APPLYING BRAKES CHECK AND ADVISE
Tech CommentsINSTALL WASHERS PER 22-2395 AS REQUESTED
Details5101477P11170FORD OF PORT RICHEY2628516-OCT-2023*RENTAL*41195909
Tech CommentsAS NEEDED.... RENTAL TRANSPORTATION PROVIDED CAS-45745659-H6T6L8
Details623747323B70210.3FORD OF PORT RICHEY3562730-JAN-2024*10C679*41985301
Customer CommentsRECALL 23B70 BATTERY MONITOR SENSOR REPLACEMENT
Tech CommentsAS PER RECALL PERFORMED RECALL AND REPLACED BATTERY MONITOR SENSOR.
Details67396881968D212FORD OF PORT RICHEY3835123-FEB-2024*18C466*42169301
Customer CommentsCUSTOMER STATES WRENCH LIGHT CAME ON TWICE AND THEN WENT OFF...CLUSTER SAID POWERTRAIN MALFUNCTION REDUCED POWER AND PRE COLLISION ASSIST NOT AVAILABLE ON CLUSTER CHECK AND ADVISE ON FORD ESP
Tech CommentsPCM C0604 C0630 ABS C0040 PINPOINT NEC TO REMOVE FRUNK FOR ACCESS CHECK PINFIT AT ABS PCM BCM ALL OK VERIFY CONITINUITY CKTS CCB61 GN/OG AND CCA07 YE BETWEEN BCM ABS AND PCM ALL OK. REPLACED AIR DAM ACTUATORS PER SSM 51718 ROAD TEST 40 MILES UNABLE TO RECREATE ANY DTCS OR VERIFY ANY WARNING MESSAGES AT THIS TIME
Details70538901968D226.9FORD OF PORT RICHEY3942207-MAR-2024ML3Z19H406B42269602
Customer CommentsCUSTOMER STATES WHEN IN BLUECRUISE OR SELF DRIVING COLLISION SENSORS DO NOT WORK AND BUBBLE GOES AWAY IN CLUSTER CHECK AND ADVISE
Tech CommentsROAD TEST TO NEAREST AVAILABLE ROAD WITH BLUECRUISE CAPABILITIES NO PROBLEMS FOUND PERFORMED AVAILABLE IPMA AND PSCM MODULE UPDATES
Details70440661968D222.9FORD OF PORT RICHEY3942207-MAR-2024PL3Z2005C42269601
Customer CommentsCUSTOMER STATES WRENCH LIGHT COMES ON WHILE DRIVING WITH POWERTRAIN MALFUNCTION FAULT LIGHT, PRE COLLISION ASSIST AND AIRBAG LIGHT COME ON CHECK AND ADVISE
Tech CommentsABS C0040:64 PCM P0573 PINPOINT CW1 Y CW2 Y CW3 Y CW4 Y CW5 Y CW6 Y REPLACED EBB ASSEMBLY PROGRAM CONFIGURE AND BLEED SYSTEM ROAD TEST RETEST SYSTEM PASS
Details7180390E81228FORD OF PORT RICHEY4096425-MAR-2024*14401*42408202
Customer CommentsCUSTOMER STATES WRENCH LIGHT, AIR BAG LIGHT, AND PRE COLLISION ASSIST NOT AVAILABLE FAULT LIGHTS CAME ON CHECK AND ADVISE ON FORD ESP.
Tech CommentsABS C0040 PCM P0573 PINPOINT LEADS TO NPF UNABLE TO DUPLICATE FAULT CONTACT HOTLINE ADVISED TO PMI BCM AND OVERLAY BOO/BPS CKTS OVERLAY CKT CCB61 GY/OG FROM BCM C228A PIN 1 TO PCM C1915B PIN H3 AND ABS C135 PIN 18 OVERLAY CKT CES09 VT/OG FROM ABS C135 PIN 16 TO PCM C1915B PIN A3 PMI BCM AND PROGRAM 2 KEYS ROAD TEST 64 MILES STILL UNABLE TO RECREATE FAULT NO WARNING MESSAGES PRESENT ON ROAD TEST
Details8154080P11251.4FORD OF PORT RICHEY4719129-MAY-2024ML3Z99632A22B42923404
Customer CommentsCUSTOMER STATES AIRBAG WARNING LIGHT IS ON.
Tech CommentsVERIFIED CONCERN, PULLED CODE B00A0 CHECKED OASIS AND FOUND TSB 23-2280 APPLIES TO CONCERN. REPLACED OSCM SENSOR PER TSB 23-2280. CLEARED CODES. RETESTED OKAY
Details81535301968D250.2FORD OF PORT RICHEY4719129-MAY-2024ML3Z17526A42923407
Customer CommentsCUSTOMER STATES WIPERS ARE MISALIGNED AND ARM PINS FELL OUT OF ARMS CHECK AND ADVISE
Tech CommentsVERIFIED CONCERN, INSPECTED WIPER ARMS AND FOUND ALIGNMENT DOWELS MISSING REPLACED BOTH WIPER ARMS. RETESTED OKAY
Details8153469P11250FORD OF PORT RICHEY4719129-MAY-2024*RENTAL*42923405
Details8182992S07251.6FORD OF PORT RICHEY4719129-MAY-2024NL3Z12A650ASC42923401
Customer CommentsCUSTOMER STATES WRENCH LIGHT, AIR BAG LIGHT, AND PRE COLLISION ASSIST NOT AVAILABLE FAULT LIGHTS CAME ON WHILE DRIVING AND THEN WENT OFF FAULT LIGHTS COME ON AT RANDOM TIMES. AND CAME ON ONCE WHEN STARTING VEHICLE CHECK AND ADVISE ON FORD ESP.
Tech CommentsVERIFIED CONCERN, P0573 C0040. VEHICLE HAS BEEN HERE MULTIPLE TIMES FOR SAME CONCERN AND THERE IS AN ACTIVE TECH LINE CASE OPEN. Contact ID :120407430 PER FSE REPLACE AND PROGRAM PCM AND BCM. RK28BN33VB9PV REPLACED PCM AND BCM AND PROGRAMED BOTH MODULES. CLEARED CODES AND TEST DROVE VEHICLE AND CONCERN DID NOT RETURN.
Details8327907E812532.7FORD OF PORT RICHEY4825319-JUN-2024PL3Z14A005DP43096501
Customer CommentsCUSTOMER STATES WRENCH LIGHT, AIR BAG LIGHT, AND PRE COLLISION ASSIST NOT AVAILABLE FAULT LIGHTS ARE ON CHECK AND ADVISE ON FORD ESP.
Tech CommentsVERIFIED CONCERN, PULLED CODES P0573, COO40. THIS IS AN INTERMITTENT CONCERN AND VEHICLE HAS BEEN IN FOR MULTIPLE REPAIRS FOR SAME CONCERN, THERE IS AN OPEN HOTLINE CONTACT ID 120407430. PER HOTLINE I WAS ABLE TO DUPLICATE CONCERN THIS TIME AND INSPECTED FOR PIN FIT ISSUES. UNABLE TO FIND AND ISSUES WITH CONNECTORS OR PINS IN CONNECTORS C2498F, C2280A, C2280B, C1915B, C135. STILL UNABLE TO ISOLATE FAULT AND PER TECH LINE REPLACEMENT OF WIRING HARNESS 12A581 AND 14A005 ARE RECOMMENDED. REMOVED FRONT AND REAR SEATS AS WELL AS CARPET. REMOVED DASH PANEL AND EVACED AC SYSTEM AND REMOVED EVAP CASE ASSEMBLY. REMOVED ALL INTERIOR TRIM AND HEADLINER. AS WELL AS CENTER CONSOLE. TO ACCESS AND REMOVE BODY HARNESS. REMOVED FRONT HEAD LAMPS, COWL PANEL, FRUNK COMPARTMENT AND BUMPER TRIM. REMOVED BJB TO ACCESS AND REPLACE FRONT HARNESS. REPLACED BOTH HARNESS 12A581 AND 14A005. REINSTALLED INTERIOR AND CHARGED AC SYSTEM. REINSTALLED HEADLAMPS AND BUMPER TRIM AS WELL AS FRUNK COMPARTMENT, AND COWL PANEL. CLEARED CODES AND TEST DROVE VEHICLE 38 MILES, CONCERN HAS NOT RETURNED AT THIS TIME. M-TIME ON RO FOR HARNESS REPLACEMENT
Details8325985P11250FORD OF PORT RICHEY4825319-JUN-2024*RENTAL*43096504
Details87202911968D265.5FORD OF PORT RICHEY5085015-JUL-2024*14A303*43292601
Customer CommentsCUSTOMER STATES STOP SAFELY NOW MESSAGE IS ON CLUSTER...FORD PASS SAYS ELECTRICAL SYSTEM FAULT DETECTED VEHICLE MAY SHUT DOWN WHILE DRIVING.
Tech CommentsVERFIED CONCERN, PULLED CODE P2C85. FOLLOWED PPT A1 A1-NO A2-NO REPLACE CHARGE PORT ASSEMBLY. REMOVED AND REPLACED CHARGE PORT ASSEMBLY. CLEARED CODES AND TEST DROVE VEHICLE. RETESTED OKAY
Details8720571P11260FORD OF PORT RICHEY5085015-JUL-2024*RENTAL*43292605
Tech CommentsAS NEEDED.... RENTAL TRANSPORTATION PROVIDED Warranty Loaner Request for CXH-02391172-Y8Q4B3
Details1032514324B56301.9PARKS FORD OF WESLEY CHAPEL5106012-NOV-2024*14G647*12446104
Customer Comments24B56 INOPERATIVE FRONT PARKING SENSORS - SOFTWARE UPDATE IMAGE PROCESSING MODULE A
Tech Commentsperformed fsa 24b56 . programmed ipma and pscm to latest calibration as per recall
Details10325177P86300PARKS FORD OF WESLEY CHAPEL5106012-NOV-2024LJ9Z10B706K1244617
Customer CommentsEV CHARGE CORD ASSEMBLY
Tech CommentsINSTALLED EV CHARGE CORD ASSEMBLY
Details1032528423B50300.6PARKS FORD OF WESLEY CHAPEL5106012-NOV-2024*10B689*12446103
Customer Comments23B50 CHARGE CORD STUCK REPROGRAM BATTERY CHARGE CONTROL MODULE
Tech Commentsperformed fsa 23b50 programmed sobdm, sobdmb, sobdmc, abs, pcm, and becm to latest calibration as per recall
Details10325066P86300.2PARKS FORD OF WESLEY CHAPEL5106012-NOV-2024BAGMH3*1244616
Customer CommentsBATTERY FAILS PERFORMANCE TEST
Tech Commentsduring inspection, found battery to fail performance test. replaced 12v battery, reset bms. vehicle starting normal now
Details10324964RAVIN301PARKS FORD OF WESLEY CHAPEL5106012-NOV-2024*RAV*12446102
Customer CommentsMULTIPOINT INSPECTION
Tech CommentsMULTIPOINT INSPECTION
Details10322812P86301PARKS FORD OF WESLEY CHAPEL5106012-NOV-2024*SERVICE*1244611
Customer CommentsFORD REAQUIRED VEHICLE PROGRAM - RAV BUYBACK VEHICLE. VEHICLE COMING IN FOR RAV DIAGNOSIS - FORD REACQUIRED VEHICLE PROGRAM. RAV BUYBACK. VEHICLE COMING IN FOR pcm and bcm programming
Tech Commentsinspected vehicle for pcm and bcm programming concerns. reviewed warranty history to figure out previous concerns. found history of unable to charge and various warning lights. performed 14 mile road test, no warning lights or driveability concerns. eec tested, no dtcs. charged vehicle, no charging concerns noted. unable to duplicate concerns. according to warranty history, various repairs have been made
Details10325341P86303PARKS FORD OF WESLEY CHAPEL5106012-NOV-2024*14G371*1244618
Customer Commentsprogram all modules
Tech Commentsprogram all remaining modules
Details1032533224P24300.3PARKS FORD OF WESLEY CHAPEL5106012-NOV-2024*14A626*12446105
Customer Comments24P24 REPROGRAM THE FRONT HATCH CONTROL MODULE FHCM
Tech Commentsperformed fsa 24p24. programmed fhcm to latest calibration as per recall
Details10378068P86322PARKS FORD OF WESLEY CHAPEL5107203-JAN-2025*RECAL*1279772
Customer Commentsthis line is for the remaining of the programming of modules we were only paid 3.0 hours instead of 5.0 hours
Tech Commentsprogramming of all modules
Damn, that's a lot of time in repair status, some of it was routine recall & CSP work, a few items regarding "Yellow Light" was related to the FCSP in a reduced charging rate, probably because the former driver manually derated the EVSE to less than 80 amp in Fordpass.
Numerous entries where the tech confirms the truck is charging fine, but the customer just does not understand his issue and never came to our forum for an education on how to operate the FCSP
Random error codes on startup happen occasionally, used as an excuse to get it into service, tech spends much time programming & reprogramming modules, not certain that it was needed.
Etc. Etc. Etc................... Cue reason to return under buyback agreement.
JMHO about the litany of service events.....
If you buy it, ask for an extended warranty.
TMND
usa
Lightning
ag
How cheap? As far as driving it, I don’t know, but the parts on that thing gotta be worth a mint regardless. Only 1200 for a tail light assembly ?
Boatman
Boatman
F250 for now
$33,000, Lariat, ER, max tow.....
At first I wondered if the owner was part of the problem. but the tech often "verified concerns". Maybe all the bugs are worked out. Maybe now that every connection and fitting has been handled a few times things will start getting loose. Its a gamble for sure. just wondering if these are common issues.
OP, I don't know if you realize this, but this truck was a RAV buyback. It has over 50k miles, so bumper to bumper is gone. And, no. Those are not common issues. Looks like it's currently being ignored too.
Ford F-150 Lightning How common is this? Screenshot 2025-01-27 211743
It also currently has trouble codes set. Looks like for ABS faults. I can't see the faults in PTS, but somebody with FDRS might be able to tell you exactly what codes the truck is currently has.
Boatman
Boatman
F250 for now
Thanks for the info. I saw that it was a buyback. Not sure what issues prompted that. They said it would have a full 1 year bumper to bumper warranty as part of the sale. Odd that it would have issues after their "139 point inspection". but, they are used car salesmen.
Boatman
Boatman
F250 for now
after spending a couple of weeks looking at used, I am starting to think that the $800 payment on a new 2024 Flash might be a decent deal.
Scorpio3d
SS/IBA car wash owner
Maybe if I got a three year 36,000 mile warranty beginning from whatever miles it has now and extended the battery warranty 50,000 miles maybe….
Now that I think about it, NO WAY!
But you do you!
Oafy44
Georgia
23 ford lightning
Landscape contractor
i have a lariat ER max tow and only had 1 battery module that failed - then got all the recalls done at same time. So probably 3 entries over 2 years.
that list looks to me like a never ending problem-
some people hate having a loan on a car ect ect but they are selling new ones with discounts and 0% financing right now.
probably get a new lariat in the 60s with full warranty and not paying interest for 6 years seems maybe the way I would go.
Whammy Bar
That looks a lot like my trucks service history. Not gonna lie...
Henry Ford
This one is most concerning to me. Did they fix it? It's presumably gone 3000 miles since it was last in for this.
$33k sounds cheap to me but I don't know what you can find a non-buyback '22 Lariat for. A bit of a gamble for sure.
Heliian
Truck is fine, seems to have had some minor electrical problems. Everything was made worse by the customers lack of knowledge on the vehicle. Most of the line items are regular updates and recalls. Some weird gremlins in there but overall if the deal was good I'd go for it.
You never know though, a brand new vehicle can have problems too.
That that gets me is when the customer says fast charging doesn't
I don't think that's entirely the case. The notes for the the complaint differentiate from fast chargers and slow chargers. The first one is that the fast don't work, but the slow did. Then the tech notes say no access to fast charger, charges fine on level 2. Well no sh** Sherlock, that's exactly what the customer told you. I'm not entirely convinced in the abilities of that tech.
However, I'm also confused about the 50kW Pro charger. I think the problem here was that the customer and the tech didn't know enough to properly diagnose what was going on.
I noticed that reference as well, also the "Yellow Light" I assumed owner was talking about the FCSP being derated, I see a lot of members nickname it Pro Charger and who knows what the Tech's are thinking when they read "customer states" that the service advisors wrote in the intake notes.
