BhamDCam
Birmingham
2023 F-150 Lightning Pro ER
I recently successfully installed the 360 cameras and front parking sensors on my 2023 Pro ER. As a simple way of giving back to this awesome community, I put together a Lightning-specific write-up in hopes that it will help others. You can find the write-up here:
F150 Lightning 360 Camera + Front Parking Sensor Installation Write-Up.pdf
Major shoutout to none other than @Jesse-Infotainment. This would not have been possible without his help.
Let me know if you have any questions! Would also love to know if anyone else make these mods too.
BhamDCam
BhamDCam
Birmingham
@boggle Smart move. I never tow so when I bought my Lightning I didn’t care about the tow tech package, not realizing that that was the only way to get the 360 cameras. Lesson learned.
Though I will say I really enjoy this kind of stuff. Researching all this kinda became a hobby of mine.
tearitupsports
Russell
Cypress, TX
Great job! This will help some other ambitious people wanting this feature.
The main thing I would like to do is figure out a way to record the OEM cameras. It is interesting that they have coax connections, so it may be possible to build some sort of recording box. The intent would be to record the cameras without interrupting any of the OEM function.
BhamDCam
BhamDCam
Birmingham
Would be neat, but I’m not sure if it is possible or not. All the cameras are coax except the third brake light camera, FYI.
captcory
cory
sw florida
'23 FORD Lightning PRO, honda pilot
Nice! when I got my no option PRO, the only two options that I really wanted was 360 camera and ACC. I have all the parts to do the ACC but haven't installed yet. Now I'll have to start collecting parts for the 360 camera and do it all at once. thanks !
BhamDCam
BhamDCam
Birmingham
Awesome. Let me know if you have any questions and I’d be happy to help.
You can't do it without some additional equipment because of the way the video is formatted for the SYNC system in the Lightning.
I think this thingamajig might work with some caveats can be use to input HDMI video from additional cameras, but capturing the car cameras I am not sure about from the description: cannot be done.
https://naviks.com/i-24078365-2022-...hdcamera-inputs-left-right-front-trailer.html
One exception to the recording from Lightning cameras seems to be if you have the Ford Security Package - but it seems to require adding another camera?:
Truck Bed Camera
The available Ford Truck Bed Camera ($249) is a smart security camera for your truck bed. When paired with an active Ford Security Package50 plan, the Ford Truck Bed Camera provides real-time truck bed monitoring via the Ford app164 when the vehicle is parked. Available on 2024 and newer F-150® and Super Duty® trucks.*
The Truck Bed Camera is like a smart home camera designed for pickup trucks. This high-definition camera mounts to your rear window, overlooking the truck bed, and records activity like reach-ins and tampering.
To power the camera, there is a hub unit hidden under the rear seats that charges itself through your vehicle’s OBD-II port. The hub also enables the camera to send alerts and footage to the cloud over cellular LTE. Through the Ford app, you can view a live stream from the camera, review stored footage, and receive alerts when activity is detected.*
The Truck Bed Camera requires activation of the Ford Security Package.**
tearitupsports
Russell
Cypress, TX
On the new IPMA what is the C242F connector (also with 4 coax) used for? Is it connected to something or left un-used?
BhamDCam
BhamDCam
Birmingham
Aside from moving the existing coax cable (for the rear camera) from C242F Pin 2 and moving it to C242 E Pin 2, you leave it alone.
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
Truck Bed Camera
I guess not available on my 23 Lightning? :(
Or could I get a 24 or newer camera & then it would work?
Check with a Ford dealership, or go with an after-market security system if Ford can't do it (more likely).
