VTbuckeye
Joseph
Vermont
19 Bolt, 16 XC90T8, 22 XC40 P8 Recharge, 17 Tacoma
120V x should not be run at more than 16 amp on a 20amp circuit (constant load should be no more than 80 percent of rated capacity). On a 15 amp circuit it should be drawing 12amp (1.44 kw less efficiency losses).
sotek2345
Engineering Manager
Good catch - not sure what I was thinking!
Revised numbers below:
Figure about 2 miles per kWhr.
So if you use the mobile charger on 240V (L2) - 240V x 30A x .95 efficiency = ~6.8kw. -> about 15 miles per hour
If you use it on 110V at 20A (16A pulled)- 110V x 16A x .85 efficiency = ~1.5kW -> about 3 miles per hour
If you use it on 110V at 15A (12A pulled) - 110V x 12A x .85 efficiency = ~1.1kW -> about 2 miles per hour
Cut each of these by ~2-3 miles per hour if charging in the cold
CRAIGC540
Craig
Moreno valley
F150 Lariot F150 Lariat lightning
Technician
I’ve been exceeding 3-3.5 mi/kWh locally, but I drive easy. I even saw it creep over 4 at one point during my errands today.
That would be me getting 3.5mi/kWh driving around town and only 7 miles to work. My family say I drive like a old man, and that was when I was a young man..
LightningShow
MA
'22 Lariat ER
Product Development
L1 charger pulls 11A from 120v outlet. That's what Prius Prime does.
Depends on the vehicle and the charger. The Bolt pulls 12A.
Silent_Thunder
Silent_Thunder
Ken
2022 F-150 Lightning Lariat ER, 1993 F-150 XL 2WD
Sustainable Landscape Design & Install
Yeah, this is my fifth electrified vehicle, second EV. I used to not run heat in my C-Max Energi plug-in to get the most range out of it. My passengers always complained!! While I haven’t gotten to that level of “hyper milling” yet, I drive it easy most days.
juzman
Justin
Metuchen, NJ
Honda Ridgeline 2017
Awesome write-up and pics! She's beautiful. I ordered Black Agate too so it was nice to see it in the wild!
Roy2001
Sacramento, CA
Tesla MX LR; Prius Prime
You are cheap, haha!
Seriously I feel the best way is to use heated seats. That's why I am glad Lariat has 2nd row heated seats. Resistance heater is a terrible idea. But again, just like AC, heap pump cannot help when environment is below 20F.
Silent_Thunder
Silent_Thunder
Ken
Ours is AMB 😅
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
One more week before my Lightning Lariat goes into production. It will be here before I realize it. Join my Mach E in the driveway. There is already a waiting list from my neighbors who drive trucks to see it and ride it. Hope I don't have to run some Disney amusement ride until everyone is happy.!!
