Looking for Lightning Model Identifers
Jiji
Rick
Finger Lakes, NY
2024 F-150 Lightning
I have some software for the Lightning and I wish to properly label the various trims from the VIN model identifier field which are the characters in the 5-7 VIN position.
For example, my 2024 Flash has a VIN with "W3L" in these positions which makes it an XLT trim. Just wondering what other model identifiers are out there or if there is a reference somewhere. I have seen comments that the trim is not encoded in the VIN but it seems to be in the Mach-E and perhaps in the Lightning as well.
For my 2022 Lariat, digits 5-7 are W1E - but that's also what every 2022 and 2023 trim has for digits 5-7. You can look at digit 8 to get SR vs. ER.
For 2024 and 2025, Pro's are W1B, XLT and Flash are W3L, Lariats are W5L and Plat are W7L. But I only have about 3-4 of each trim so a small sample.
The difference between 2024-25 XLT and Flash is also position 8. For our trucks it is the battery size,
2024 K=SR (XLT), R=ER (Flash).
2025 K=SR (XLT), U=123 kWh ER (Flash), 7=143 kWh ER (Flash).
You can go to carfax.com etc, and look at hundreds of used VINs if you want to find other patterns.
Jiji
Jiji
Rick
Finger Lakes, NY
Thanks for the fast replies, pre-2024 VIN are the single code W1E code but I'll run with the newer codes for 2024 onward.
Use is just for a friendly label so it doesn't matter if I get them wrong.
