M/KWh Mileage, 2024 Platinum, Extended, Max Tow with 275/50/22s K03s 50 PSI A/C Tonneau Cover, 11,500 Miles
Randys Lightning
Randy
24 Lightning, 20, Road Glide, 23 Kaw H2 SX SE, 24 Yamaha FX HO Waverunner, +
Ret. US Army Nuclear Artillery and Ret. P&G Mechanical Engineer
75 Mph 1.9 Mi KWh, Spirited around Town and Highway 2.3 Mi KWh, Normal Around town 2.7 Mi KWh Just FYI, 100% One Pedal Drive.
Ford F-150 Lightning M/KWh Mileage, 2024 Platinum, Extended, Max Tow  with 275/50/22s K03s 50 PSI A/C Tonneau Cover, 11,500 Miles New K03s 2
Enjoy your Lightning & BTW impressive stable of vehicles, I haven't mentioned before I have a 2012 Kaw ZX14r, a blast to ride....
DiverBroski
Jared
F-150 Lightning 2022
I'm following this thread now! I need new tires in about 12 months. Weighing these vs.
OPEN COUNTRY A/T III EV
CoolViper777
George
Pittsburgh
2019 Ford Expedition & potential F150 Lightning owner
Software Engineer
50 psi tire pressure? I don't yet have a Lightning, but I'm wondering how the ride is at that high of a pressure, as I'm assuming the door decal pressure is probably under 40 psi.
Also, does that high pressure encourage more wear in the middle tread as it's close to be overinflated?
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
These are trucks, not cars. Each tire needs to be capable of supporting a ton.
Smoothest riding pickup I have ever driven.
Heliian
Door sticker should say 42psi. My factory 20" tire was max 51psi so the rims should be able to handle it.
LT rated tires, which the op has but didn't mention can go as high as 80psi in some cases but the rim has to also be able to handle it.
In general, you always want even wear on your tires, more weight = higher pressure to maintain tire shape. You are correct though, centre tread wear is indicative of overinflation.
Adventureboy
How do you like the KO3s? Great, meaty-looking tire.
Randys Lightning
Randys Lightning
Randy
Absolutely Love them, even in 14 inch deep snow, crazy good, not cheap though and much better than the K02s were.
Randys Lightning
Randys Lightning
Randy
Reactions: dww
Lucky Larry
Calgary, AB, Canada
23 Lightning Platinum, 25 Mach-E, 17 RX 350
Fun Fact the BFG KO tires are Winter rated as indicated by the three peak and snowflake symbol on the side wall. Thererfore you wont need to buy a seperate set of winter tires if you live in an area that gets lots of snow in the winter, or in Canadian provinces or US states that mandate the use of winter tires .
