No lane centering with cruise control after IPMA update.
bryansocko
Bryan
2023 Lightning Platinum
I spent the better part of yesterday getting all my modules up to date with FDRS.
I did the 3 hour IPMA last night. Now I no longer have the lane centering with adaptive cruise control.(The white hands on the steering wheel never appear in the top left of the cluster)
It's turned on via the screen control. There are no dtcs stored.
I know the IPMA is working as lane keep will still ping pong me between the lines.
I am thinking this is a coding issue on the module.
Should I load the as built data from Ford via Foescan?
Does anyone have the Blue Cruise 1.4 coding to enable it? Maybe the new firmware needs new coding?
Ford F-150 Lightning No lane centering with cruise control after IPMA update. 20250301_120247
rugedraw
Javier
Miami
Auto Sales
Were you wearing your seat belt?
bryansocko
Bryan
That is new behavior with the update.
Before lane centering with adaptive cruise control engaged with or without a seatbelt being buckled. Now it will not engage lane centering with cruise control without the driver seat belt being buckled .
This is a very well known issue (added feature?) for this IPMA update. I know it's documented here but if you have 30 minutes to kill, start over at the ICE forum.
https://www.f150gen14.com/forum/threads/ecu-module-programming-guide-using-fdrs.8249/post-570293
TLDR; Original premise was this IPMA update was bad because a few people saw that lane centering was broke. Turns out Ford added the feature (bug?) that seat belt is needed for BC.
As far as overriding this, you'll have to read the rest of that thread as I don't recall if that's possible.
rugedraw
Javier
Miami
Auto Sales
It's not. It's hard coded in there.
Marcelo Zanetti
Marcelo
New York
Ford F150; Ford F-150 Lightning; Ford Explorer;
My BlueCruise stopped working Al off a sudden.
Cruise control engages but BlueCruise doesn’t come on.
tearitupsports
Russell
Houston, TX
You might have just turned off lane centering with the button on the steering wheel. Thats what happened to me. All I had to do was turn the lane centering back on and it worked again.
rugedraw
Javier
Miami
Auto Sales
Message me the VIN if you'd like and I'll take a look and see if I see anything helpful.
Marcelo Zanetti
Marcelo
New York
Oh! That's a very good possibility. Somehow it started to work again this morning. So, perhaps I did touch the lane centering button by accident and turned it on again...
Thanks for the reply anyway...
Marcelo Zanetti
Marcelo
New York
Thanks for the help Xavier,
Russel just posted above that I might have hit the lane centering button by accident.
It started to work this morning again...
tks....
