Phone as key, MyView, Drive mode... questions
MTBski150
PA
Quebec
F150 2021, Subaru Outback 2011, Mazda3 2010.
Hi
Has anyone figured out:
1 - if phone can be used as key? you wouldn't have to carry the key with you at all.
2 - avoid MyView configuration showing up most of the time when starting the truck
3 - truck to start up on last drive mode (Eco for example)
Either I didn't read the user manual correctly, or these are obvious gaps from Ford.
In case the trim matters, I have an XLT 302A, V8, 4X4, screw.
mmdpg
Massachusetts
2008 Bullitt Mustang, 2021 F-150 Lariat
I have a Lariat 502A and if I shut it off in a drive mode other than Normal, when I start it the next time a message shows up for about 10 seconds asking if I want to remain in "Sport" or whatever mode I had it in last. Unless you press OK pretty quickly it goes back to Normal mode.
