EvilUser007
2024 Flash, 2015 Model S, 2017 MS
Anybody know what the torque is supposed to be?
EvilUser007
Mine was torqued properly. So they just replaced the nuts with a newer revision and brought it back to me. About 3 hours all in including the hour drive each way.
The nut was different? Did they add a cotter pin or make it a locknut?
FloridaMan655321
1973 F100, 2024 Flash
Thats funny complaining about mobile service not available. I scheduled mine and just bring a book to read at the dealership.
MountainAlive
Massachusetts, USA
Since many seem to not actually have a problem, is there any reason I can't just check if the nut is still there, put a torque wrench on it and check and if OK call it a day? Anyone know what the torque is supposed to be?
I did this when I was in the first recall batch. But you’ll still want to bring it to the dealer so they can clear your VIN from the recall and get that off your trucks record.
EvilUser007
I will but if I have to drive it to the dealer I’d like to check the torque before I do! Do you know what it’s supposed to be?
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
If they change anything more than the nut, do they check/redo alignment as part of the recall?
flyct
flyct
Jerry
South Florida
Blissfully Retired
Robert
NW Ontario Canada
Contractor
When I read the recall instructions there was no mention of doing an alignment.
That is the way I read it too.
So back to the comment by Eviluser 007 that if the nut is already torqued correctly, just keep driving it , rather than let them mess up the alignment and later ya notice when the tire wear has ruined a set of expensive tires?
I think they should provide at the very least an alignment check, if they touch anything, and if they change the upper control arm they know the truck needs an alignment, since there is no way around that, and it shouldn't be our cost for putting the alignment back to proper setting.
JIMINGA
JIM
ATLANTA
2024 Lucid Air Pure; 2024 Lightning Lariat ER (Avalanche)
Psychiatric Social Worker
Dealership sending a Mobile “enhanced technician” to my home June 4 to inspect/address this recall on my ‘24 Lightning.
iam-s-Hon
Richard
2021 Job 1 MME Premium AWD ER Iconic Silver, 2024 Lightning Lariat AMB
I can imagine a situation- rare as it may seem- where someone does this but has some. Issue at some point later and is denied a warranty claiim/service or worse.
Getting to a dealer can be a pain but is ignoring a recall vs a CSB worth it?
JIMINGA
JIM
ATLANTA
Mobile Tech from dealership came to the house yesterday, inspected recall assembly/joint/nut. FAILED. Dealership picking up truck Monday, completing recall, then returning it Wednesday. Will request alignment.
JIMINGA
JIM
ATLANTA
Free loaner offered.
