Software update check hangs
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
Using SYNC to check for software updates, it just sits there and spins. Does not seem to matter where vehicle is, in town, at home. Any suggestions?
10 mm wrench to disconnect the negative on the 12v battery for about 10 minutes.
Adventureboy
Make sure you give it a couple of hours to complete updates just in case one is in progress. Gateway updates will cause any communications to the outside world to hang until the updates are complete. If it has been a couple of hours and symptoms persist, you can pull fuse 32 and reinstall it a few minutes later to restart your gateway/modem.
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
I assume that pulling the negative off the 12v battery will also reset the gateway, correct?
Reactions: GDN
rugedraw
Javier
Miami
Auto Sales
Yes, all modules. I would recommend 20 minutes, though.
It would, but since there is something awry with the status screen, I'd heed the advice to wait a couple hours, then if it continues to be a problem, then either pull the fuse or the 12v negative terminal.
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
Left the negative off for 20 min and reconnected. That seemed to do the trick, looks like I have karaoke update coming, woohoo!
OMG, FoMoCo your OTA process stinks.
Thanks for the help everyone.
