Spray in Bed Liner and Bed Bolts
rdr854
Northern Virginia
18 Volvo V90, 22 Ford F150 Lightning, 23 Outback
Yesterday, I stopped by my local Line-X dealer for a quote on a spray in bed liner. During the course of the conversation, the Line-X dealer stated that they could no longer remove the bed bolts unless I provided a new set. The reason is because Ford apparently issued a bulletin that the bolts are single use. Thus, they will end up spraying over those bolts - just like the OEM provided spray in bed liner.
beatle
Springfield, VA
According to the age of this thread, it seems like this has been a thing for at least a few years:
https://www.ford-trucks.com/forums/1563931-line-x-and-1-time-use-bed-bolts-4.html
Looks like the bolts are some kind of trilobular design that cuts their own threads. Here is an example of a trilobular bolt. Note the odd cross section.
https://www.mcmaster.com/tri-lobula...unded-head-thread-forming-screws-for-plastic/
Strange that the installer wouldn't tape over the bolt heads before spraying, then just peel off afterwards. A few people in that thread say you can peel off the Line-X with a utility knife if you need to get to the bolt head. Some also said the bed may vibrate if reusing the bolts, or you can use Loctite when reinstalling them, though I guess that's not an option if you're taking it to a shop that says they won't reuse them.
How much did they quote you? I hear the Line-X is nicer than OEM and a bit cheaper to boot.
rdr854
Northern Virginia
As I think about it, spraying over the bolts that hold the bed to the chassis should not be a big problem. Chances are that if you are having to remove the bolts, messing up the spray in bed liner is the least of your problems.
bryan995
François
San Diego
F150 Lightning
Having LineX done tomorrow. So the consensus is to spray over the bolts eh? Sounds like even supplying new ones comes with risk that it won’t be as tight as original.
ErichKeane
Erich
Gaston, Oregon
2022 F150L Lariat ER, 2020 Niro EV, 1990 300zx TT
Senior Compiler Engineer
My last truck they had painted over it, and it wasn't a problem. It would PROBABLY be a bigger issue if you ever wanted a 5th wheel or something.
JustaProGuy
MI
Lightning
Spray over them, I'll be doing the same based on the recommendation from linex
Alan168
Alan
Massachusetts
2022 Lightning Platinum, Rapid Red Metallic
FYI, I just had Line-X put a spry-in bedliner on my new Lightning. They said they would NOT guarantee the job if they sprayed over the bed bolts. I talked to the Ford dealer and they said it's ok to remove the bed bolts and reuse them, so that's what Line-X did. For better or worse?!
jerock
Jerry
Kansas
F150 Lightning
Linex sprayed over mine. They said nothing about voiding the warranty. I’ll be pretty upset if that is the case
merek
Buffalo, NY
F150 Lightning Lariat ER [6/20]
I talked to the shop that did my non-LineX about this -- they sprayed over them, not really sure why you would ever really want to remove them without having to do major work already.
